POV-Ray : Newsgroups : povray.newusers : arrays Server Time
22 Mar 2026 05:58:17 EDT (-0400)
  arrays (Message 1 to 4 of 4)
Subject: arrays
Date: 18 Feb 2002 19:53:39
Message: <3c71a213@news.povray.org>
Hi
Am I right in thinking that to set a float value equal to the nth element of
an array I would do something like:
#declare my_array = array[3] {10,11,12}
#declare my_value = array[2];
hence my_value would take its value from the 2nd array element, ie  = 11.
The only problem is, I get a
"Parse Error: All #declares of float, vector, and color require semi-colon
';' at end if the
language version is set to 3.5 or higher.
Either add the semi-colon or set the language version to 3.1 or lower."
error - even though the semi-colon is present.
Thanks
jim
Subject: Re: arrays
Date: 18 Feb 2002 20:42:32
Message: <3c71ad88@news.povray.org>
jimbobjim <jim### [at] blueyondercouk> wrote:
: #declare my_array = array[3] {10,11,12}
: #declare my_value = array[2];
: hence my_value would take its value from the 2nd array element, ie  = 11.
  Firstly, it has to be:
#declare my_value = my_array[2];
  Secondly, the indexing starts from 0, which means that '12' is assigned
to 'my_value'.
Subject: Re: arrays
Date: 19 Feb 2002 04:56:12
Message: <3c72213c@news.povray.org>
news:3c71ad88@news.povray.org...
11.
oops, this is what is have in the pov code, but I had a little finger
trouble in typing the email...but I still get the missing semi-colon error.
Jim
Subject: Re: arrays
Date: 19 Feb 2002 06:27:12
Message: <3c72368f@news.povray.org>
: but I still get the missing semi-colon error.
  I don't.
  Are you sure it's not issued for an error in another line (perhaps a previous
line)?
