POV-Ray : Newsgroups : povray.newusers : Animation Question Server Time
14 Jun 2026 07:22:16 EDT (-0400)
  Animation Question (Message 11 to 13 of 13)
Subject: Re: Animation Question
Date: 31 Jan 2002 17:39:34
Message: <3C59E472.8030508@txcyber.com>
Bob,
  Thanks for your help in both replies.
Here are the object and camera coordinates that I'm working with right now.
camera location <0, 15, -6>
        look_at < 0, 15, 0>
object position #1 <8, 12, -8>//starting position
        position #2 <-45, 12, 50>//crossing from right to left in front
of camera as it travels into the distance.
        position #3 < 0, 50, 60>
        position #4 <45, 12, 50>//pos#2, #3 & #4 should make an arch
going across from left to right.
        position #5 <-8, 12, -8>//ending the path just outside of camera
view on left.
I understand how to use (From, Using, & To) for the movements, but the
spline/path is giving me problems now. Also, if I can figure out the
spline coordinates, I might just close the end of the path closest to
camera and have a full figure8, keeping everything in front of the
camera. I can get straight lines and curved lines but now crisscrossing
lines or figure 8 yet.
Thanks again for the help,
Les
bob h wrote:
> "Les Patterson" <les### [at] txcybercom> wrote in message
> news:3C5### [at] txcybercom...
>> Antialias=Off
>> Antialias_Threshold=0.1
>> Antialias_Depth=2
>> Input_File_Name=Fly.pov
>> Output_File_Path=C:\My Documents\PovAnimation
>> Initial_Frame=1
>> Final_Frame=50
>> Initial_Clock=0
>> Final_Clock=1
>> Cyclic_Animation=on
>> Pause_when_Done=off
>> Will this work?
>> Les
>> This animation will be an aircraft flying around in the scene, but so
>> far I haven't been able to get the object rotation values to work right.
> A bit delayed response from me but there isn't a Output_File_Path= (unless
> someone added it without me realizing it. No, I checked the v3.5 docs, there
> isn't).  You use Output_File_Name= for the path and leave off the file name
> if you just want the scene file name to prefix onto the frame files.  Or you
> can use the full path plus name different from your scenes name too.
> Output_File_Name=C:\My Documents\PovAnimation\
> or
> Output_File_Name=C:\My Documents\PovAnimation\fly.pov
> is what you want to be using.
> bob h
Date: 1 Feb 2002 11:48:10
Message: <3c5ac6ca@news.povray.org>
> Bob,
Welcome to whatever I can manage to help with.
> camera. I can get straight lines and curved lines but no crisscrossing
That movement you have set up is probably uneven.  The spline path will yank
the airplane around through it as though on the end of a snapping whip, well
what I mean is that the interploation of points between won't be very
steady.  Of course you would like acceleration and deceleration I'm sure but
you must be careful how you set the points up.  The spacing between them
should relate to speed, i.e. shorter spacings are slower and longer spacings
are faster.  There's been a lot done in the way splines are calculated
within POV-Ray but Chris Colefax's generator macro is external and I can't
remember how it goes about it.  Would be obvious once you've rendered out
the animation and viewed it.
3D graphing paper (nonexistant I guess :-)) would be perfect for planning
such things out.  A figure-8 wouldn't be a problem anyway, it shouldn't
tangle up.  ;-)
bob h
Date: 1 Feb 2002 15:02:27
Message: <3C5B1122.7060406@txcyber.com>
Bob,
  I'm still pretty new at Pov and it takes time for some of these things
to set in to the old brain. Old age I guess. I'm going to play with the
spline points for a while till I get it all worked out.
  Thanks again for your help,
Les
>> Bob,
> tangle up.  ;-)
> bob h
