POV-Ray : Newsgroups : povray.newusers : testing slrn Server Time
19 Sep 2025 16:26:22 EDT (-0400)
  testing slrn (Message 1 to 10 of 11)
Subject: testing slrn
Date: 28 Jan 2002 23:38:38
Message: <3c56274e$1@news.povray.org>
Pardon the posting, but I'm trying to get a news client working and I'm not
sure if news.povray.org is a NNTP-based client. Bear with me: either this will
work, or it won't.  Either way, the annoyance factor should ultimately be
minimal.
Thanks for your forbearance.
==Mark
Subject: Re: testing slrn
Date: 29 Jan 2002 05:28:38
Message: <3C567990.9E68DA4E@engineer.com>
news.povray.org is not a NNTP-based client.
_____________
Kari Kivisalo
Date: 29 Jan 2002 06:38:00
Message: <3C5689B6.E20C62B8@atosorigin.com>
Of course not, it's a server!
Non Sine Numine
http://grimbert.cjb.net/
Date: 29 Jan 2002 08:23:10
Message: <3c56a23e@news.povray.org>
Mark M. Wilson <doo### [at] anderbrockdebianorg> wrote:
: ==Mark
  You probably want to make yourself a .signature file in your home directory.
Date: 29 Jan 2002 11:17:18
Message: <3c56cb0e@news.povray.org>
>minimal.
>==Mark
OK, it worked.  If you're curious, I was testing slrn -- still can't seem to
get all the groups listed by using wildcards -- gotta' borrow the group names
from the netscape mail client and add them manually, but I'm happy to report
it DOES work!
Thanks for your patience
--Mark again
Date: 29 Jan 2002 14:30:53
Message: <slrna5dere.df2.steve@zero-pps.localdomain>
>minimal.
Slrn, you've made the best choice IMHO.
                                             or http://start.at/zero-pps
  3:09pm  up 113 days,  6:59,  1 user,  load average: 1.00, 1.00, 1.00
Date: 29 Jan 2002 16:26:07
Message: <slrna5e4rh.l0d.ron.parker@fwi.com>
On 29 Jan 2002 14:30:53 -0500, Steve wrote:
> User-Agent: slrn/0.9.6.2 (Linux)
Hear, hear!
Incidentally, you're both using an old version of slrn.  The new version
has some nice bugfixes.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 30 Jan 2002 13:08:01
Message: <slrna5fpnc.s1i.steve@zero-pps.localdomain>
>Hear, hear!
You forgot to mention the evil bold type it uses for unread message
subjects, good job I kept a backup of the old version.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 30 Jan 2002 14:04:34
Message: <slrna5ggu0.vvf.ron.parker@fwi.com>
Mine uses a pleasing blue color.  Perhaps you should check your .slrnrc.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 30 Jan 2002 14:12:22
Message: <slrna5ghco.vvf.ron.parker@fwi.com>
(Actually, blue is what my ssh term uses to mean bold, so your mileage
obviously varies.)  Try adding this to your .slrnrc:
set highlight_unread_subjects 0
From the manual:
   Type: integer
   Default: 1
   If non-zero, the subjects of unread articles are highlighted. There
   are two possible ways of doing this:
   When set to one, unread subjects are printed bright (when using
   colors) or bold (in monochrome mode). This will obviously not have any
   visible effect if the subject is printed bold or in a bright color
   anyways. Besides that, the special color ``default'' does not have a
   bright version.
   When set to two, unread subjects are printed in the color you set with
   unread_subject. In this case, only subjects of unread articles can be
   colored by score.
