POV-Ray : Newsgroups : povray.newusers : difference and bicubic_patch Server Time
18 Jun 2026 23:44:08 EDT (-0400)
  difference and bicubic_patch (Message 1 to 7 of 7)
Subject: difference and bicubic_patch
Date: 21 Nov 2001 13:56:45
Message: <3bfbf8ed@news.povray.org>
hello,
i made a shape with bicubic_patch and failed as i tried to difference it
from a box:
difference{
box{<0,0,0>,<1,1,1> pigment{color Green}}
object{
        a_bicubic_object
}//difference
the result was an empty scene.
is there any way to come by this problem?
Subject: Re: difference and bicubic_patch
Date: 21 Nov 2001 14:18:16
Message: <3bfbfdf8$1@news.povray.org>
hi marabou,
hey!  thats one i can answer!  difference is a constructive
solid geometry option, and that only works with "primitive"
shapes, such as cylinders, boxes, spheres, etc.  all of those
shapes except the donut (toroid) are listed in the scene
language help document in section 2.2.
good luck, miker
"marabou" <not### [at] availableyet> wrote in message
news:3bfbf8ed@news.povray.org...
> hello,
> from a box:
> difference{
> object{
>         a_bicubic_object
> }//difference
Date: 21 Nov 2001 14:41:54
Message: <3bfc0381@news.povray.org>
MR wrote:
> hi marabou,
> good luck, miker
miker, i fear you are right. and this confirms my results. yes. hm. smack.
but how to come by this problem? is there another possibility?
thanks for the hint!
>> hello,
>> from a box:
>> difference{
>> object{
>>         a_bicubic_object
>> }//difference
Date: 21 Nov 2001 16:31:05
Message: <3bfc1d19$1@news.povray.org>
hi marabou,
i would say that the easiest option is to tug on some of the
control points of your patch to difference the box.  does
that make sense?
good luck, miker
news:3bfc0381@news.povray.org...
> MR wrote:
> > hi marabou,
> > good luck, miker
> >> hello,
it
> >> from a box:
> >> difference{
> >> object{
> >>         a_bicubic_object
> >> }//difference
Date: 21 Nov 2001 16:46:03
Message: <3bfc209b@news.povray.org>
MR
> hi marabou,
What do you mean with "primitive"? Difference truly works with every object
which has got a well defined "inside" and "outside". So it works fine with
planes, isosurfaces, heightfields and (with MegaPov) meshes too.
Jonathan.
Date: 21 Nov 2001 17:08:40
Message: <3bfc25e7@news.povray.org>
AFAIK, CSG calculations need to know whether a certain point is inside
a given object or not. This means that the objects participating in the CSG
construct must have well-defined inside (ie. povray can calculate if the
point is or isn't inside the object).
  The insideness test is defined for most primitives (because it's so easy).
However, meshes and bicubic patches make an exception because they don't have
a well-defined inside. It's not clear how to calculate whether a point is
inside them or not in a general case.
  For closed meshes a test can be done, tough, and this has been implemented
in MegaPov.
Date: 24 Nov 2001 13:51:10
Message: <3bffec1e@news.povray.org>
"marabou" <not### [at] availableyet> wrote in message news:3bfbf8ed@news.povray.org...
> hello,
> from a box:
> difference{
> object{
>         a_bicubic_object
> }//difference
As warp explained, this won't work directly. However, heightfields _do_
difference correctly. Depending on what you want to do, this will work: render
an orthographic view of your patch object, with the cutting side pointing
towards the camera, and a black to white gradient assigned to the patch -- back
to front with respect to the camera view -- and use ambient one and no lights.
Use the resulting image as a heigtfield and difference it from the cube. In 3.5
or MegaPOV, using max_extents on your patch object can help you get the proper
scaling values for the heightfield.
Hope that helps :)
Batronyx ^"^
