POV-Ray : Newsgroups : povray.newusers : adding 2 pigments Server Time
19 Jan 2026 01:26:59 EST (-0500)
  adding 2 pigments (Message 1 to 10 of 11)
Subject: adding 2 pigments
Date: 11 Oct 2001 17:00:49
Message: <3bc60881@news.povray.org>
Is there a way to add 2 pigments together into a new pigment? Something like
"average", but only adding the values, without dividing afterwards. I tried
all sort of things, even splitting both pigments into different color
channel functions, adding the functions, and then combining them again into
the new pigment.. but it's quite complicated and messy, only for such a
simple thing. I think there must be a simpler solution and I'm just not
seeing it.
For example, I have one pigment which is <0,0,0> everywhere and has a stripe
of <1,0,0> somewhere, and another pigment which also is black and has
another red stripe. The resulting pigment should be black as well, but have
both stripes. If I use average, it has both stripes, but they get very
dark. I must be overlooking something..
Right now I have this, which does not what I want:
#declare Pigment3 = pigment {
   average
   pigment_map {
      [1 Pigment1]
      [1 Pigment2]
Any ideas?
#macro C(X,Y)cylinder{X*x<X,0,-Y/2>.1}#end#macro U(R,X,Y)intersection{torus{.9
.1}box{-1 0rotate y*R*90}translate<X,0,Y>scale 1-z*.5}#end union{U(0,0,0)U(1,0
,0)U(2,-1,-1)U(1,1,0)U(1,1.5,-3)U(1,2,0)U(3,1,0)U(2,2,0)U(0,3,0)U(3,2,.5)C(.1,
2)C(.8,1)C(.8,-1)C(1.1,1)C(1.9,-1)pigment{rgb 10}rotate x*90translate<-1,0,4>}
Subject: Re: adding 2 pigments
Date: 11 Oct 2001 17:48:16
Message: <slrn9sc4t3.d4h.ron.parker@fwi.com>
>seeing it.
You can use larger values in the declarations of the two source pigments.
If you make your red stripes be rgb <2,0,0> it should balance out in the end.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 12 Oct 2001 04:22:21
Message: <3bc6a83d@news.povray.org>
Yes, that's what I'm doing in my complicated method, but it only works for
patterns, not pigments. Or is there an easy way to take a pigment, and
multiply it by 2?
Date: 12 Oct 2001 05:06:19
Message: <3bc6b28b@news.povray.org>
Elias Pschernig <eli### [at] aonat> schrieb in im Newsbeitrag:
3bc60881@news.povray.org...
like
tried
into
> seeing it.
stripe
have
>    average
>    pigment_map {
>       [1 Pigment1]
>       [1 Pigment2]
> Any ideas?
You could put both pigments in a function then add the to functions in
another function and use this as your pigment.
Date: 12 Oct 2001 07:43:19
Message: <3bc6d757$1@news.povray.org>
You can add, subtract, divide and multiply pigment vectors the same as any
other vector:
rgb <1,1,1>*5
rgb <1,0,0>+<1,1,0>
rgb <1,1,1>*<1,2,1>
....etc.
-tgq
"Elias Pschernig" <eli### [at] aonat> wrote in message
news:3bc6a83d@news.povray.org...
pigments.
end.
> multiply it by 2?
union{U(0,0,0)U(1,0
1,
Date: 12 Oct 2001 09:57:37
Message: <3bc6f6d1$1@news.povray.org>
> other vector:
> rgb <1,1,1>*5
> rgb <1,0,0>+<1,1,0>
> rgb <1,1,1>*<1,2,1>
> ....etc.
Yes, vectors, but not pigments. Not even pigment functions. By now I think I
already have the simplest solution for what I want to do, but it is very
complicated:
(All it does is adding two pigments)
#declare PigmentFunction1 = function { pigment { InputPigment1 } }
#declare PigmentFunction2 = function { pigment { InputPigment2 } }
#declare PatternRed1 =  function { pattern { function { PigmentFunction1(x, y, z).x }
#declare PatternGreen1 =  function { pattern { function { PigmentFunction1(x, y, z).y
#declare PatternBlue1 = function { pattern { function { PigmentFunction1(x, y, z).z }
#declare PatternAlpha1 = function { pattern { function { PigmentFunction1(x, y, z).t }
#declare PatternRed2 = function { pattern { function { PigmentFunction2(x, y, z).x } }
#declare PatternGreen2 = function { pattern { function { PigmentFunction2(x, y, z).y }
#declare PatternBlue2 = function { pattern { function { PigmentFunction2(x, y, z).z }
#declare PatternAlpha2 = function { pattern { function { PigmentFunction2(x, y, z).t }
#declare PatternRed = function {
   PatternRed1(x, y, z) + PatternRed2(x, y, z)
#declare PatternGreen = function {
   PatternGreen1(x, y, z) + PatternGreen2(x, y, z)
#declare PatternBlue = function {
   PatternBlue1(x, y, z) + PatternBlue2(x, y, z)
#declare PatternAlpha = function {
   PatternAlpha1(x, y, z) + PatternAlpha2(x, y, z)
#declare OutputPigment = pigment {
   average
   pigment_map {
      [function { PatternRed(x, y, z) } color_map {[0 rgb 0][1 rgb x * 4]}]
      [function { PatternGreen(x, y, z) } color_map {[0 rgb 0][1 rgb y * 4]}]
      [function { PatternBlue(x, y, z) } color_map {[0 rgb 0][1 rgb z * 4]}]
      [function { PatternAlpha(x, y, z) } color_map {[0 rgb 0][1 rgbt t * 4]}]
Now it is understandable why I thought there's a simpler solution I guess :)
I still hope someone can simplify it..
Date: 16 Oct 2001 14:49:25
Message: <3BCC80B5.51E34E83@hotmail.com>
> > other vector:
> > rgb <1,1,1>*5
> > rgb <1,0,0>+<1,1,0>
> > rgb <1,1,1>*<1,2,1>
> > ....etc.
> complicated:
Elias, see my code below.
It isn't tested much...
- Maybe you can give it a few tests ?
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
// Copyright 2001 by Tor Olav Kristensen
// mailto:tor### [at] hotmailcom
// http://www.crosswinds.net/~tok
#version 3.5;
#macro MixPigments(Pigment1, Pigment2)
  #local Alpha = color rgbt <0, 0, 0, 1>;
  #local PFn1 = function { pigment { Pigment1 } }
  #local PFn2 = function { pigment { Pigment2 } }
  #local R_Pigment =
    function { PFn1(x, y, z).x + PFn2(x, y, z).x }
    color_map { [ 0 color Black ] [ 1 color 4*Red   ] }
  #local G_Pigment =
    function { PFn1(x, y, z).y + PFn2(x, y, z).y }
    color_map { [ 0 color Black ] [ 1 color 4*Green ] }
  #local B_Pigment =
    function { PFn1(x, y, z).z + PFn2(x, y, z).z }
    color_map { [ 0 color Black ] [ 1 color 4*Blue  ] }
  #local T_Pigment =
    function { PFn1(x, y, z).t + PFn2(x, y, z).t }
    color_map { [ 0 color Black ] [ 1 color 4*Alpha ] }
  #local MixedPigment =
     average
     pigment_map {
        [ R_Pigment ]
        [ G_Pigment ]
        [ B_Pigment ]
        [ T_Pigment ]
  MixedPigment
#end // macro MixPigments
#declare InputPigment1 =
  bozo
  scale 0.3
  color_map {
    [ 0 color Cyan ]
    [ 1 color Magenta ]
#declare InputPigment2 =
  gradient y
  turbulence 0.3
  color_map {
    [ 0 color Yellow ]
    [ 1 color Blue ]
sphere {
  <0, 0, 0>, 1
  pigment { MixPigments(InputPigment1, InputPigment2) }
light_source { <1, 2, -2>*100 color White }
  location <0, 0, -5>
  look_at <0, 0, 0>
Date: 17 Oct 2001 05:58:39
Message: <3bcd564f$1@news.povray.org>
Yes, that looks better :) Especially not defining separate pattern functions,
it is what looked worst in my approach. Btw, I discovered that the transparent
component doesn't work, it seems to be a limitation of pigment functions. I'm
not sure yet if it is a bug, but the .t always returns 0, no matter what the
transparency of the pigment used is. (The transparency in my code doesn't work
as well)
Date: 17 Oct 2001 09:27:13
Message: <3bcd8731@news.povray.org>
news:3bcd564f$1@news.povray.org...
I'm
the
work
> as well)
't' is the fourth float in a 4D vector, as used in julia_fractal for
example.  That's why it remains zero, it isn't seeing a 4D vector present.
I don't know of a dot to get filter or transmit.
Bob H.
Date: 17 Oct 2001 11:17:54
Message: <3bcda122@news.povray.org>
Yes, thanks, I actually knew that once and forgot it again :) Looking at the
docs, it seems I can use .red .green .blue .transmit and .filter, and .x .y
.z works for the first 3 (but .t not for the 4th).
