POV-Ray : Newsgroups : povray.newusers : Rotating a POV object vs. rotating a prism. Server Time
19 Sep 2025 20:45:03 EDT (-0400)
  Rotating a POV object vs. rotating a prism. (Message 1 to 3 of 3)
Subject: Rotating a POV object vs. rotating a prism.
Date: 18 Sep 2001 17:46:11
Message: <3ba7c0a3$1@news.povray.org>
Hi!
When I rotate a pov ray object like a the box, POVRay will rotate it about
it's center point.  However, if I make a prism, it rotates the prism around
the first point created.  How can I make a prism object and if I apply the
rotate parameter have it rotate around the center of the prism object?
Anybody know a work around for this?  Thanks,
Arie
Subject: Re: Rotating a POV object vs. rotating a prism.
Date: 18 Sep 2001 17:55:35
Message: <3ba7c2d7@news.povray.org>
Arie L. Stavchansky <ari### [at] bellatlanticnet> wrote:
: When I rotate a pov ray object like a the box, POVRay will rotate it about
: it's center point.
  Nope, it rotates it around <0,0,0>.
:  However, if I make a prism, it rotates the prism around
: the first point created.
  If the first point is located at <0,0,0> then that's true. If it's somewhere
else, then it isn't (is it will always rotate around <0,0,0>).
:  How can I make a prism object and if I apply the
: rotate parameter have it rotate around the center of the prism object?
  What is the center of a prism?
Date: 19 Sep 2001 04:03:06
Message: <3BA851D2.649D6052@inapg.inra.fr>
If you're using 3.5, include the transforms.inc file and then use the
Center_Trans macro to center your object (actually its bounding box so it may
not look like you want it to look) around the origin.
#include "transforms.inc"
#declare MyPrism=prism{...}
object {MyPrism
    Center_Trans(MyPrism, x+y+z)
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
