POV-Ray : Newsgroups : povray.newusers : Making a window and molding Server Time
22 Mar 2026 09:29:42 EDT (-0400)
  Making a window and molding (Message 1 to 2 of 2)
Subject: Making a window and molding
Date: 13 Sep 2001 21:19:55
Message: <3ba15b3b$1@news.povray.org>
Hmm I've tried to make a window by following how I made the doorway, and
apparently and obviously it didn't work.  How do I 'cut' a cylinder in half
lengthwise in order to make rounded molding?  If I can.
here's my code:
#include "woods.inc"
#declare Wall_Texture=
texture{
 pigment{ color White-(White-Khaki)*0.495 }
 normal{ wrinkles 0.2 }
#declare light_wood=
pigment{ P_WoodGrain7A color_map {M_Wood7A} }
#declare dark_wood=
pigment{ P_WoodGrain14A color_map {M_Wood14A} }
#declare board_length= 1.5;
#declare board_width= 0.25;
#declare Floor_Texture=
texture{
 pigment{
  gradient y triangle_wave
  pigment_map{
   [ 0.0 light_wood]
   [ 1.0 dark_wood ]
  warp{ repeat board_length*z offset 0.50*y }
  warp{ repeat board_width*x offset board_length*5/2*z }
 normal{
  boxed
  slope_map{
   [0.5 <1.0, 0>]
   [1.0 <0, 0>]
  bump_size 0.1
  scale <board_width,1,board_length>
  warp{ repeat board_length*z }
  warp{ repeat board_width*x offset board_length/2*z }
light_source{
 <9,9,9>
 color White
 area_light
 <2,0,0> <0,0,2>
 8,8
 adaptive 0
 jitter
camera{
 location <0,5,11>
 look_at <0,5,-10>
// Right Wall
box{
 <10,0,-12>,<11,10,12>
 texture{
  Wall_Texture
// Left Wall
difference{
 box{
  <-11,0,-12>,<-10,10,12>
  texture{
   Wall_Texture
 box{
  <-12,0,-5>,<-9,8,-8>
  texture{
   pigment{
    color White
// Back Wall
difference{
 box{
 <-10,0,-12>,<10,10,-13>
 texture{
  Wall_Texture
 box{
  <-11,0,-8><9,8,-4>
  texture{
   pigment{
    color White
  translate y*6
// The Floor
box{
 <-10,-1,-12>,<10,0,12>
 texture{
  Floor_Texture
// The Ceiling
box{
 <-10,10,-12>,<10,11,12>
 texture{
  Wall_Texture
// A Round Table
union{
 cylinder { <0,0,0><0,0.1,0> 1.5 }
 cylinder { <0,0,0><0,1.4,0> 0.3 translate 0.1*y }
 cylinder { <0,0,0><0,0.1,0> 3 translate 1.5*y }
 texture { T_Wood1 }
 translate -7.25*z
Subject: Re: Making a window and molding
Date: 14 Sep 2001 07:42:19
Message: <3ba1ed1b$1@news.povray.org>
> // Back Wall
> difference{
>  box{
>  texture{
>   Wall_Texture
>  box{
>   <-11,0,-8><9,8,-4>
>   texture{
>    pigment{
>     color White
>   translate y*6
The box you are trying to cut out of the back wall does not intersect the
wall
you want the cutout box to be slightly thicker than the wall
the box you are trying to remove is located between the z coordinates -4
and -8 while the wall is between -12 and -13 i.e., they don't intersect
you wall is <-10,0,-12>,<10,10,-13> (20w x 10h x 1t)
try this box for your window:
<-2,2,-11><2,6,-14>
this will cutout a window 4x4 units in the middle of the back wall
-tgq
