POV-Ray : Newsgroups : povray.newusers : Making shadows and making more visible wall texture Server Time
19 Jan 2026 03:33:40 EST (-0500)
  Making shadows and making more visible wall texture (Message 1 to 5 of 5)
Subject: Making shadows and making more visible wall texture
Date: 7 Sep 2001 16:32:15
Message: <3b992ecf$1@news.povray.org>
How do I make shadows?  How do I make my wall texture more visible?  Here's
my code:
#include "woods.inc"
background {color White}
light_source{
 0*x
 color White*1.1
 area_light
 <8,0,0> <0,0,8>
 8, 8
 adaptive 0
 jitter
 translate <40,180,40>
 location <0, 0, 11>
 look_at 0
 angle 40
// Right Wall
box{
 <1,1,1>,<-1,-1,-1>
 texture{
  pigment{
   color 1-(1-Khaki)*.490
  normal{
   wrinkles 0.25
   scale 0.005
  finish{
   ambient 0.266167
   diffuse 0.884867
 scale <0.1, 1.5, 3.5>
 translate <-2.938508, 0, .140896>
// Left Wall
box{
 <1,1,1>,<-1,-1,-1>
 texture{
  pigment{
  normal{
   wrinkles 0.25
   scale 0.005
  finish{
   ambient 0.266167
   diffuse 0.884867
 translate <2.938508, 0, .140896>
// back wall
box{
 <1,1,1>,<-1,-1,-1>
 texture{
  pigment{
  normal{
   wrinkles 0.25
   scale 0.005
  finish{
   ambient 0.266167
   diffuse 0.884867
 scale <3.5, 1.86, 0.1>
 translate <0,0,-6.838508>
// The floor
#declare light_wood= pigment {P_WoodGrain7A  color_map {M_Wood7A} }
#declare  dark_wood= pigment {P_WoodGrain14A color_map {M_Wood14A} }
#declare board_length= 1.5;
#declare board_width= 0.25;
box{
 <2.938508,0,6.838508>,<-2.938508,0,-6.838508>
 pigment{
  gradient y triangle_wave
  pigment_map {
   [0.0 light_wood ]
   [1.0 dark_wood ]
  warp{
   repeat board_length*z offset 0.37*y
  warp{
   repeat board_width*x offset board_length*5/2*z
 normal {
  boxed
  slope_map {
   [0.5 <1,0>]
   [1.0 <0,0>]
  bump_size 0.1
  scale <board_width,1,board_length>
  warp{
  warp{
   repeat board_width*x offset board_length/2*z
translate y*-2.0185
scale <1.3,0,1.22>
// The ceiling
box{
 texture{
  pigment{
   color 1-(1-Khaki)*.49000245
 translate y*2.0185
 scale <1.3,0,1.22>
Wade
Subject: Re: Making shadows and making more visible wall texture
Date: 7 Sep 2001 17:33:34
Message: <slrn9pif7n.s4t.steve@zero-pps.localdomain>
>my code:
>light_source{
> 0*x
> color White*1.1
> area_light
Have a read of the docs on what area_lights do.
At the moment you havn't got anything that would cast
much of a shadow, only the walls and the floor.  Really
you want the walls and floor to be illuminated.
Remove the area light code from your light and put a
sperer at <0,2,0> and you should see it's shadow.
Hope some of that helps.
PS: I always use MidnightBlue for my background, but I suppose it's
a matter of taste.
 10:27pm  up 56 days, 33 min,  2 users,  load average: 1.00, 1.24, 1.35
Date: 7 Sep 2001 17:45:27
Message: <3b993ff7@news.povray.org>
The main problem you are having here is that your walls are transparent.
This can be seen by changing the background color.
  The easiest way of defining an opaque color is to use: rgb <1,1,1> (or
whatever values between 0 and 1 inside the vector).
  I revised your code a bit and perhaps this is more what you were looking
for?
---------8<-------------8<-------------8<--------------8<-------------8<-----
light_source
{ 0, color 1
 //area_light <8,0,0> <0,0,8> 8, 8 adaptive 0 jitter
 //translate <40,180,40>
 location <0, 0, 11>
 look_at 0
 angle 40
box
{ <-2.9,-2.1,-4><2.9,2,12>
  inverse
  pigment { rgb 1 }
  normal { wrinkles .2 }
// The floor
box{
 pigment{
  pigment_map {
   [0.0 light_wood ]
   [1.0 dark_wood ]
  warp{
  warp{
 normal {
  boxed
  slope_map {
   [0.5 <1,0>]
   [1.0 <0,0>]
  bump_size 0.1
  warp{
  warp{
translate y*-2.0185
scale <1.3,1,1.22>
Date: 9 Sep 2001 20:16:24
Message: <3b9c0658$1@news.povray.org>
Do I need to inverse the ceiling?  And how do I shorten the shadows?  here's
the code:
light_source{
 0*x
 color 1
 area_light
 <8,0,0> <0,0,8>
 8, 8
 adaptive 0
 jitter
 location <0, 0, 11>
 look_at 0
 angle 40
// Right Wall
box{
 <-2.9,-2.1,-4>,<2.9,2,12>
 inverse
 texture{
  pigment{
  normal{
   wrinkles 0.2
// Left Wall
box{
 inverse
 texture{
  pigment{
  normal{
   wrinkles 0.2
// back wall
box{
 inverse
 texture{
  pigment{
  normal{
   wrinkles 0.2
// The floor
box{
 pigment{
  pigment_map {
   [0.0 light_wood ]
   [1.0 dark_wood ]
  warp{
  warp{
 normal {
  boxed
  slope_map {
   [0.5 <1,0>]
   [1.0 <0,0>]
  bump_size 0.1
  warp{
  warp{
translate y*-2.0185
scale <1.3,0,1.22>
// The ceiling
box{
 texture{
  pigment{
 translate y*2.0185
 scale <1.3,0,1.22>
Date: 10 Sep 2001 03:28:38
Message: <3b9c6ba6@news.povray.org>
"Wade" <Zav### [at] aolcom> wrote in message
news:3b9c0658$1@news.povray.org...
Don't know what's going on that you might need to inverse the ceiling, no
media in there and normals shouldn't matter.
To shorten shadows you just need to narrow the area light axis lengths
(<8,0,0>,<0,0,8> smaller numbers there) or move the light farther away if
you can.  In v3.5 you can also use the parallel keyword in the light which
will shorten shadows in a way too.
Looks to me like you have the light far outside the room walls.
Don't scale by zero, BTW.  Use a very small number if you must but zero gets
changed to 1 and causes a warning message.
Bob H.
