POV-Ray : Newsgroups : povray.newusers : Colored Shadows? Server Time
11 Apr 2026 01:31:34 EDT (-0400)
  Colored Shadows? (Message 1 to 5 of 5)
Subject: Colored Shadows?
Date: 14 Aug 2001 14:49:04
Message: <3b7972a0@news.povray.org>
I hate to monopolize this newsgroup, but no one else is really asking
questions, so here I go again.
As I mentioned, I am trying to make web page buttons as my first POV
project.  I have so far nice-looking buttons, but I want a little more.  I
actually got the idea of using an engraving effect from here:
http://arena.cwnet.com/povdocs/pov51.htm
but I haven't quite gotten what I want.
I can get the letters to appear to be cut out of the button, but when I do
it, I lose the green color of the letters, I presume because most of the
engraved letter is in shadow and so it shows up black.  Do you know how I
can create this engraved effect and yet still retain the full color of the
letters?
Thank you, I appreciate your help,
Hershel
My code (without any fancy color manipulations):
#include "textures.inc"
#declare Cam3 = camera { location<3.1,2,-7>
                         look_at <3.1,2,0>}
camera{Cam3}
light_source{<-12,15,-15> color White}
blob {
    threshold .65
    cylinder { <0,0  ,0>, <6,0  ,0>, 1, 1 }
    cylinder { <0,.5 ,0>, <6,.5 ,0>, 1, 1 }
    cylinder { <0,1  ,0>, <6,1  ,0>, 1, 1 }
//    pigment { Blue }
   pigment { rgb <0.1 , 0.5, .9>  }
    finish { phong 1 }
    translate .65*z
text { ttf "timrom.ttf" "View Pipeline" .1, 0
    pigment { Black}
    translate <0, .20, 0.03>
    finish { diffuse .9 }
plane {<0,0,-1>, -.25
       pigment {color White}
       finish { diffuse 10 }
Subject: Re: Colored Shadows?
Date: 14 Aug 2001 15:40:03
Message: <cnubl9.ndj.ln@micha.riser>
> letters?
When you want to cut something away, you have to use the 'difference' of
the both objects. So:
difference{
  A
  B
This will cut away object B from object A. The texture the resulting
objects depends where you put the 'texture' statements. If you put it at
the end then the whole object has the same texture, if you put it into each
of the two objects then it will have all over the texture form A except
where B cuts A.
This kind of operation is called 'CSG'. There is some documentation about
it (besides the manual of course!) at
http://www.cs.mtu.edu/~shene/COURSES/cs3621/LAB/povray/csg.html
Using difference this should look like:
>                          look_at <3.1,2,0>}
> camera{Cam3}
difference{
> blob {
>     threshold .65
> //    pigment { Blue }
>     finish { phong 1 }
>     translate .65*z
// >     pigment { Black}
I thought you wanted them green. So you need
  pigment{Green}
Note that I have not tested the scene. I hope it works all the same ;)
- Micha
P.S. The pages at www.povworld.de/objects and www.povworld.de/book might be
interesting for you. The first provides more than 250 source code for
povray objects, with the second you find a list of tutorials found on the
web.
Ceterum censeo Microsoft esse dividendum.
Date: 14 Aug 2001 15:45:33
Message: <3b797fdd@news.povray.org>
Yes, I realize that, I just forgot to include that part of my code.
Your additions are exactly what I have here.
>   pigment{Green}
That, too. :)
I have tested it and the problem I described in my first letter, with the
shadows being black and not green, is precisely the problem with the scene.
Thanks,
Hershel
Date: 14 Aug 2001 16:10:06
Message: <ha0cl9.1kj.ln@micha.riser>
> scene.
Okay, I rendered it. It is just that the black area lies in shadow and
therefore is black. There are various ways to avoid the problem. The
easiest is probably to use 'ambient' in the finish.
So use
  finish{diffuse 0.3 ambient .7}
for the text's finish. Try some different combination for the two values.
Other possibilities would be:
- change the lighting, so that the cut out is everywhere lit (several light
sources, aera light)
- make the cutting out less deep
- use radiosity
Micha
Date: 15 Aug 2001 05:10:55
Message: <3b7a3c9f@news.povray.org>
> So use
Thank you.  That did it.
Hershel
