POV-Ray : Newsgroups : povray.newusers : Bryce Server Time
14 Jun 2026 13:10:47 EDT (-0400)
  Bryce (Message 11 to 14 of 14)
Subject: Re: Bryce
Date: 25 Apr 2001 12:56:39
Message: <3AE701DA.FA7B93C6@inapg.inra.fr>
Warp wrote:
> An attitude like "why do you use POV-Ray when this or that hypersuper
> high-end renderer is much better" shows clearly that the person has a
> pirate version of that program.
I wouldn't say "clearly", though the piracy problem exists. Lots of people
involved in 3d have access to legit copies of software they could never afford
themselves, because they attend a CG class or work for a CG company. So the
"who's got the biggest one" attitude is annoying but more related to
testosterone than to piracy per se IMHO. Pov people tend to have an "attitude"
too...
About less high-end software like Bryce or Vue, it's also debatable. Someone who
can afford the hardware to run Pov smoothly can also afford these programs, and
older versions of them are often available for (almost) free in magazines, or
bundled with other programmes (like Bryce3D with Poser 4).
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Subject: Re: Bryce
Date: 26 Apr 2001 00:14:50
Message: <3AE7A104.5B32578B@pacbell.net>
Gilles Tran wrote:
> Pov people tend to have an "attitude" too...
Say what !?!
Ken Tyler
Subject: Re: Bryce
Date: 28 Apr 2001 16:11:22
Message: <2i8metc8v037jkdo70j6cou0me7jdslp6q@4ax.com>
On Sat, 21 Apr 2001 11:41:01 +0200, "Janne Eriksson"
<jan### [at] idese> wrote:
>A friend of mine claims that Bryce is the one and only 3D program to use...
>I have never used Bryce myself, only POV Ray, and would like to ask some
>more experienced users here for some more info on Bryce, e.g. comapred to
>POV Ray...? Is POV the winner :-) ?
For things involving height fields or objects that can be represented
similarly, Bryce is quite useful; it's far easier to tweak and test
them then it is in POV, IMO. But I find it very difficult to work with
for anything else; it makes far more sense to me to lay stuff out with
coordinates than by moving stuff around on the screen (and for the
same reason I don't use programs like Moray). I also don't like the
texturing model as much as I do POVRay's.
I feel like I've got greater control in general in POVRay, overall. I
have seen some spectacular images done in Bryce, though. I suspect
that to some extent the answer is that it depends both on the artist
and the type of images one wishes to create. But I'm odd; I don't
believe in One True Program under any circumstances. :)
Subject: Re: Bryce
Date: 27 Jul 2001 12:53:01
Message: <3B61B964.2000109@nospam>
Janne,
I have Bryce4, and after paying the amount of money that I did, I think
that it should do more.
It's easier to use than POV because of the semi-realtime rendering, but
it lacks some things that can be found in free software such as POV.
I've been into 3D modelling about two years now and the best 3D
modelling software I've found, that's reasonably priced, is 3C Canvas
Pro at www.amabilis.com.
If you are comfortable with writing all the code then POVRay is by far
the best way to go, simply the most powerful raytracer out there, and
it's FREE.
Les
Janne Eriksson wrote:
> Hi!
> /Janne
