POV-Ray : Newsgroups : povray.newusers : Trig Troubles Server Time
22 Mar 2026 12:24:30 EDT (-0400)
  Trig Troubles (Message 1 to 6 of 6)
Subject: Trig Troubles
Date: 3 Mar 2001 13:31:06
Message: <3aa1386a@news.povray.org>
I want to create a ring of random width made of randomly spaced particles.
What I get is random particles within a square boundary.  I've stared at
this for 45 minutes now.  Where am I screwing up?
looprun, ringminrad1, ringwidth1, seed1-4, and deftex are all previously
declared.
#while (looprun < 4000)
 #declare x1 = (ringminrad1 + (ringwidth1 * rand(seed1))) *
cos(radians(90*rand(seed2)));
 #declare z1 = (ringminrad1 + (ringwidth1 * rand(seed1))) *
sin(radians(90*rand(seed2)));
 #declare posnegx = rand(seed4);
 #if (posnegx < 0.5)
    #declare posnegx = -1;
 #else
    #declare posnegx = 1;
 #declare posnegz = rand(seed4);
 #if (posnegz < 0.5)
    #declare posnegz = -1;
 #else
    #declare posnegz = 1;
 sphere {
    <0,0,0>,1
    rotate <90*rand(seed3),90*rand(seed3),90*rand(seed3)>
    scale <rand(seed3),rand(seed3),rand(seed3)>
    translate <posnegx * x1,rand(seed3),posnegz * z1>
    texture {deftex}
 #declare looprun = looprun + 1;
Subject: Re: Trig Troubles
Date: 3 Mar 2001 15:34:25
Message: <3aa15551$1@news.povray.org>
What I'm doing wrong is calling rand twice, once for the x value, the other
for the z, thus getting two different angles for each component.  I'm bound
to get weird results that way.  I should declare the angle beforehand, thus
getting only a single random value with which to translate to a position.
While I'm at it, if I change those 90s to 360s, I don't have to bother with
the posneg determinations...
No need to reply...  I'm an idiot.
Thanks for listening to me babble, though.
- Matthew
"Matthew Green" <iam### [at] yahoocom> wrote in message
news:3aa1386a@news.povray.org...
> declared.
>  #if (posnegx < 0.5)
>  #else
>  #end
>  #if (posnegz < 0.5)
>  #else
>  #end
>  sphere {
>     <0,0,0>,1
>     texture {deftex}
> #end
Date: 3 Mar 2001 17:50:09
Message: <3aa17521@news.povray.org>
Matthew -
Just in passing - it doesn't require idiocy to make a mistake (plus, idiocy
would preclude the likelihood of correcting your problem); and, your
'babble' taught me something. All-in-all, not a bad day's work. :-)
Setep
Date: 3 Mar 2001 20:14:04
Message: <3AA197D1.A5A6D1F7@peak.edu.ee>
I see you already found the answer to your problem. However I think you could
cut out much of the trig stuff by using POV's built-in vector functions;
v_rotate() in particular seems to do exactly what you need, or perhaps
vaxis_rotate()
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 4 Mar 2001 10:14:34
Message: <3aa25bda$1@news.povray.org>
Matthew -
Setep
Yup ... been there, done that ;)
and . . . in my experience, it is the mistakes that usually lead me to
the most interesting places.  Those areas that I never would have
thought to explore . . .  the place where most new ideas spring from.
Serendipity ;)
Y
Date: 10 Mar 2001 15:40:53
Message: <3AAA906F.204B1E48@hotmail.com>
Hello Matthew
POV-Ray has some very useful built in functions that you
can use for this. So there's no need to do this "manually"
as you seem to be doing.
See my example code below.
It uses the vrotate() function (as also Margus suggested).
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
http://hjem.sol.no//t-o-k/tokpicts.html
http://www.crosswinds.net/~tok
> declared.
>  #if (posnegx < 0.5)
>  #else
>  #end
>  #if (posnegz < 0.5)
>  #else
>  #end
>  sphere {
>     <0,0,0>,1
>     texture {deftex}
> #end
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
#version 3.1;
global_settings { ambient_light color -White }
background { color Blue/2 }
light_source {
  50*<-2, 1, -1>
  color White + Yellow
  location 15*<0, 1, -2>
  look_at <0, -2, 0>
#declare DefTex = texture { pigment { color White + Blue } }
#declare RingMinRad = 12;
#declare RingWidth = 4;
#declare RR = seed(314);
#declare LoopRun = 0;
#while (LoopRun < 4000)
  #declare Radius = RingMinRad + RingWidth*rand(RR);
  #declare Angle = 360*rand(RR);
  #declare Vector = Radius*vrotate(x, Angle*y);
  sphere {
    <0, 0, 0>, 1
    scale <rand(RR), rand(RR), rand(RR)>
    rotate 90*<rand(RR), rand(RR), rand(RR)>
    translate Vector + rand(RR)*y
    texture { DefTex }
    no_shadow
  #declare LoopRun = LoopRun + 1;
#end // while
