POV-Ray : Newsgroups : povray.newusers : newbe-text question Server Time
19 Jun 2026 05:37:20 EDT (-0400)
  newbe-text question (Message 1 to 3 of 3)
Subject: newbe-text question
Date: 11 Jan 2001 18:37:50
Message: <3a5e43ce$1@news.povray.org>
greetings,
I'm trying to make a marmer box in wich text is engraved,
I'm trying to create a "difference" between the box and the text this does
works but the text it is just engrave a littlebit in the box.
I've tried scaling the text, increasing its "thickness" but it all result in
the same effect.
Does enybody know why this is?
thanks,
Subject: Re: newbe-text question
Date: 11 Jan 2001 18:58:26
Message: <3a5e48a2@news.povray.org>
Hm, I would guess that your textobject is at the "wrong" position. Try
moving it towards the box ...?
It is more likely that someone can help you, if you post the relevant part
of your code as well. If it's just a few lines long it's okay to post it
along with your message.
Marc-Hendrik
Date: 14 Jan 2001 17:10:15
Message: <3a6223c7@news.povray.org>
"Jordy" <jor### [at] dontspamjetroncom> wrote in message
news:3a5e43ce$1@news.povray.org...
> greetings,
in
> the same effect.
    Sounds like something that confused me about the text object at first -
when you increase it's thickness it moves it's 'back' face away from it's
front face (rather than moving both faces away from the centre) - depending
on how you've got things set up this could account for your engraved text
not getting any deeper - try translating the text further into the box.
HTH,
Scott Hill.
Software Engineer.
E-Mail        : sco### [at] innocentcom
PGP Key       : http://pgpkeys.mit.edu:11371
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
