POV-Ray : Newsgroups : povray.newusers : black hightfields Server Time
22 Nov 2025 05:14:33 EST (-0500)
  black hightfields (Message 1 to 10 of 13)
Subject: black hightfields
Date: 10 Jan 2001 00:46:06
Message: <3a5bf71e@news.povray.org>
I have managed to insert a hightfield, but it comes out black,  if I try and
add a texture pigment or color to it I get "object or directive expected"
errors.  What am I not understanding here?
Subject: Re: black hightfields
Date: 10 Jan 2001 00:49:24
Message: <3A5BF81E.C91FCA71@pacbell.net>
It sounds like a very simple syntax error but I can't give you a
detailed analysis without seeing the code you are using. Try
posting just the HF portion of your code so we can take a closer
look at it.
Date: 11 Jan 2001 07:46:06
Message: <3a5dab0e$1@news.povray.org>
ok, I've tried the following:
background { color SkyBlue }
Height_Field {gif "d:\fract001.gif"}
also tried putting it in as an object, adding trans forms etc
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3A5BF81E.C91FCA71@pacbell.net...
and
expected"
> look at it.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 11 Jan 2001 07:52:28
Message: <3a5dac8c$1@news.povray.org>
"RWard" <rmw### [at] swbellnet> wrote in message
news:3a5dab0e$1@news.povray.org...
Your height field has no pigment. Try:
 Height_Field {gif "d:\fract001.gif" pigment{rgb<1/2,1/1/2>}}
(the background is irrelevant - that is a seperate object).
Date: 11 Jan 2001 07:52:51
Message: <chrishuff-8682E8.07543311012001@news.povray.org>
In article <3a5dab0e$1@news.povray.org>, "RWard"
You have an extra "}" bracket...you should always make sure your
brackets match up, a "}" for every "{".
Christopher James Huff
Date: 11 Jan 2001 07:53:33
Message: <3a5daccd$1@news.povray.org>
Oops, that should have been:
 Height_Field {gif "d:\fract001.gif" pigment{rgb<1/2, 1, 1/2>}}
Date: 11 Jan 2001 11:09:27
Message: <3a5ddab7@news.povray.org>
your are correct!
Tom, tried it and get parsing error message "object or directive expected
but undeclared identifier height_field found instead"
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-8682E8.07543311012001@news.povray.org...
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 11 Jan 2001 11:20:13
Message: <3a5ddd3d@news.povray.org>
HA! case sensitivity!
news:3a5ddab7@news.povray.org...
> your are correct!
Date: 11 Jan 2001 11:22:51
Message: <3a5ddddb@news.povray.org>
> your are correct!
... but presumably it's still black (or have you added a pigment statement
as well as removing the }?)
Date: 11 Jan 2001 11:25:57
Message: <3a5dde95$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3a5ddddb@news.povray.org...
ack, scrap that last message. I hadn't taken in that you'd still got a
problem. Yep, case is wrong. And none of us spotted it. The shame. The
ignomy.
