POV-Ray : Newsgroups : povray.newusers : a question concerning normals Server Time
22 Nov 2025 03:51:54 EST (-0500)
  a question concerning normals (Message 1 to 3 of 3)
Subject: a question concerning normals
Date: 24 Dec 2000 15:39:48
Message: <3a465c20.35055548@news.povray.org>
What's the difference between the float value which follows the
pattern type (inside a normal statement) and the bump_size value?
Which one should I play with in order to control the amount of
perturbation? Can I set an accuracy value for normal patterns
(to get better results with patterns which are not likely to be used
as normal patterns)?
Subject: Re: a question concerning normals
Date: 24 Dec 2000 17:55:01
Message: <3a467ec5@news.povray.org>
Specifying a float after the pattern name is simply a shortcut for
specifying a bump_size value - there is no difference in the rendering, and
either can be used to control the amount of perturbation.
As for accuracy, this is generally determined only by the rendering
resolution - all POV-Ray's internal patterns are algorithmic, and can be
scaled to any reasonable size without degradation (barring precision limits,
and a small bug with the current implementation of "noisy" patterns).
Level of detail becomes important with image based patterns (i.e. bump_map),
for which POV-Ray offers the interpolation feature, and turbulence that you
add to patterns.  With turbulence the detail is determined by the settings
you use - generally, increasing the octaves value should add extra, smaller
perturbations which you might want if viewing a pattern very closely.
Date: 24 Dec 2000 21:32:51
Message: <chrishuff-0D2009.21340524122000@news.povray.org>
In article <3a467ec5@news.povray.org>, "Chris Colefax"
> be scaled to any reasonable size without degradation (barring
> precision limits, and a small bug with the current implementation of
> "noisy" patterns).
Actually, the "accuracy" is a constant in the official version, and is
always set to 0.02, so it probably could give inaccurate results in
normals with finely scaled patterns. This only applies to normals, and
only normals using slope_maps or which aren't built-in.
MegaPOV allows you to set this "delta" value with the "accuracy"
keyword, which defaults to 0.02 in the normal statement.
Christopher James Huff
