POV-Ray : Newsgroups : povray.newusers : Newbie syntax problem Server Time
17 Jul 2026 14:50:41 EDT (-0400)
  Newbie syntax problem (Message 21 to 23 of 23)
Subject: Re: Newbie syntax problem
Date: 12 Nov 2002 16:56:20
Message: <chrishuff-911ED4.16554312112002@netplex.aussie.org>
In article <3DD1354B.28FB473B@att.net>, LibraryMan <mrm### [at] attnet>
wrote:
> Well, I haven't gotten around to learning to use/write macros yet;  I
> suspect much of the scene I'm working on could be done in more efficient
> ways, coding-wise, but I'm just not up to reinventing that wheel yet...
No need to reinvent any wheels, I posted a working version in another
message.
http://tag.povray.org/
Date: 12 Nov 2002 21:00:45
Message: <3DD1B253.575E6908@pacbell.net>
Christopher James Huff wrote:
> In article <3DD13CF9.CA8287AE@att.net>, LibraryMan <mrm### [at] attnet>
> wrote:
> > Just a point of info I'd like to clarify (or maybe I shouldn't open this
> > can of worms):
> > If I had declared only 2D vectors like so:
> > #declare v_01 = <0.5, 0>;  ... (rather than the 3D I used)
> I think this is the main problem...POV doesn't seem to support declared
> 2D vectors, it seems to promote them to 3D. A language oddity that
> probably isn't worth fixing in 3.5, something to watch out for in 4.0.
Actually it was an intentional design decision. By design the program
presumes the user was brain damaged at the time he wrote the 2D vector
and corrects if for him rather than stopping and issuing an error message.
Microsoft calls such behavior "user friendly" :)
Should it be fixed, and if so in what way? There are only a couple of
places where a 2D vector statement is useful while there are dozens of
places where a 3D vector is mandatory. I think the current behavior
is useful and would support its continued use if asked to vote on it.
Ken Tyler
Date: 12 Nov 2002 21:45:16
Message: <chrishuff-349F18.21444512112002@netplex.aussie.org>
In article <3DD1B253.575E6908@pacbell.net>, Ken <tyl### [at] pacbellnet>
Simple:
Assigning to a vector results in a vector of the same size as the
original. If the "source" is too small, it is extended with 0's. (except
for scalars, where every component of the resulting vector gets set to
the scalar's value) If it is too big, it is truncated.
If something needs a 3D vector, it gets one, whether you give it a
scalar, a 2D vector, or a 10D vector. If something needs a 2D vector, it
gets one. The same for scalars, 4D vectors, 5D vectors...maybe POV could
be changed to handle any size vectors, though some functions would still
require specific sizes.
#declare scalar = 1; //scalar is a scalar value, one float
#declare vect2d = < 0, 0>; //vect2d is a 2D vector
#declare vect3d = < 0, 0, 0>; //vect3d is a 3D vector
scalar = < 1, 2> results in 1.
scalar = < 1, 2, 3> results in 1.
vect2d = < 1, 2, 3> results in < 1, 2>, maybe giving a warning.
vect3d = < 1, 2> results in < 1, 2, 0>.
vect2d = 3.14 results in < 3.14, 3.14>.
vect3d = 3.14 results in < 3.14, 3.14, 3.14>.
This is what I think anyone would expect from reading the existing
documentation, and what seems most useful.
> I think the current behavior is useful and would support its
What would you use the current behavior for? It seems unexpected that
declaring a 2D vector results in a 3D vector, it requires workarounds to
get the desired result, and I can't think of any time you would actually
want it.
