POV-Ray : Newsgroups : povray.newusers : Reading data from a file Server Time
12 Feb 2026 01:13:18 EST (-0500)
  Reading data from a file (Message 1 to 2 of 2)
Subject: Reading data from a file
Date: 4 Oct 2002 13:03:12
Message: <3D9DC91C.4040806@is2.dal.ca>
I have a nice long file, in the format:
-1.000000E+01 -1.000000E+01 -1.000000E+01 1 1 0
-1.000000E+01 -1.000000E+01 -9.000000E+00 1 1 0
-1.000000E+01 -1.000000E+01 -8.000000E+00 1 1 0
-1.000000E+01 -1.000000E+01 -7.000000E+00 1 1 0
-1.000000E+01 -1.000000E+01 -6.000000E+00 0 1 -1
-1.000000E+01 -1.000000E+01 -5.000000E+00 0 1 -1
-1.000000E+01 -1.000000E+01 -4.000000E+00 0 1 -1
The first three columns are x, y, and z coordinates. The next three are
data associated with the coordinates (to be represented as colour, size,
etc..)
I haven't had much luck loading these into PovRay. Pov seems to want
comma separated numbers, but this isn't feasable. I tried loading the
numbers in one at a time with:
#read (datafile,buffer)
Then output them with:
#debug str(buffer,0,1)
but it seems to loose negative signs and get generally confused.
Any suggestions?
-- Simon
Subject: Re: Reading data from a file
Date: 4 Oct 2002 14:36:06
Message: <3d9ddf95@news.povray.org>
  Why not?
  If you want to add the commas, you can use any editor with
search&replace and replace the whitespaces with commas.
  -something -something -something is a substraction and POV-Ray probably
reads it as such.
