POV-Ray : Newsgroups : povray.newusers : Help with frame_number Server Time
22 Mar 2026 00:43:19 EDT (-0400)
  Help with frame_number (Message 1 to 3 of 3)
Subject: Help with frame_number
Date: 20 Aug 2002 01:02:40
Message: <3D61CD05.7040206@global2000.net>
I declared some variables that are used by if-else statements to control
the apperence of my before-after Mars landscape.  I used a switch
statement to set the variables to different values for different frames,
but when I rendered it with the command line +KFI1 +KFF7, only the first
case version of the scene is rendered for all seven frames.  How do I
get the frames to show the different versions of the scene?
Here're the variables and the switch statement.  I have tested the
actual code manually by changing the variables' values before I made the
switch statement so I know that the if-else code that choose between the
different scene elements works fine so I didn't include that here.
#declare have_water = 0;
#declare have_clouds = 0;
#declare dust_storm = 0;
#declare night = 0;
#declare flood = 0;
#if(clock_on)
#switch(frame_number)
#case(1)
#break  //use values already set
#case(2)
#declare night = 1;
#break
#case(3)
#declare have_water = 1;
#declare have_clouds = 1;
#break
#case(4)
#declare flood = 1;
#break
#case(5)
#declare flood = 0;
#declare night = 1;
#break
#case(6)
#declare night = 0;
#break
#case(7)
#declare dust_storm = 1;
#break
Brendan
Subject: Re: Help with frame_number
Date: 20 Aug 2002 14:09:41
Message: <B98843C0.2EEF%fidel.viegas@artrecognition.co.uk>
Hi Brendan,
I have just tried it on Megapov 0.7 and Povray 3.5 and I didn't have any
problems with it. I have run the code and it selected all 7 frames.
You better double check your system.
All the best
Fidel.
in article 3D6### [at] global2000net, Brendan Ryan at
ary### [at] global2000net wrote on 20/8/02 6:00 am:
> #declare night = 0;
> #declare flood = 0;
> #if(clock_on)
> #case(1)
> #case(2)
> #declare night = 1;
> #break
> #case(3)
> #break
> #case(4)
> #declare flood = 1;
> #break
> #case(5)
> #declare flood = 0;
> #declare night = 1;
> #break
> #case(6)
> #declare night = 0;
> #break
> #case(7)
> #break
> #end
> #end
> Brendan
Date: 20 Aug 2002 19:01:49
Message: <3D62C9F0.1080208@global2000.net>
Fidel viegas wrote:
> Hi Brendan,
Oh, I just had the incorrect assumation that it would fall through the
switch statement.
Brendan
