POV-Ray : Newsgroups : povray.newusers : Can't get this mapped properly. Server Time
14 Jun 2026 03:45:34 EDT (-0400)
  Can't get this mapped properly. (Message 11 to 14 of 14)
Subject: Re: Can't get this mapped properly.
Date: 22 Jul 2002 15:44:40
Message: <3D3C6090.5070601@indecisions.org>
hughes b wrote:
> "Jon B" <prm### [at] indecisionsorg> wrote in message
> news:3D3### [at] indecisionsorg...
>>Ahh, yes yes, by your method I do understand that I would get the full
>>view of it interacting with my finish/normal statements.  The image_map
>>method has proved to be very sucessful in this case.  If for some reason
>>I'm not satisfied with the image_map method, I will definately follow
>>your image_pattern method. Thank you very much, both you guys :-)
>>Pretty much the finalized image of the start buttons.
>>http://www.hostriot.com/072002/help-4.png
> YW from me, glad that is all you wanted to get done. Thought it was more
> complex a question. I agree that the image pattern would help distinguish
> between the imprints and plastic, just that it might not seem neccessary for
> this depending on the lighting angles and scale.
> Looking at the button again I think you need the torus to drop lower on the
> inside edge. Although it would then begin curving away from the central
> depression requiring another torus to reverse the curve direction back
> inward. In other words a second, smaller, clipped torus at the conjunction
> of the first and the sphere.
http://www.hostriot.com/072002/New-Buttons.jpg
I'm was redoing the buttons because I didn't like how they looked.
Right now I'll be adding a slightly more curved edge at the ring on top
of the button.  I also switched over to the image_pattern method which I
found to work better since now I get the phong interaction with the lights.
-Jon
Date: 22 Jul 2002 15:59:26
Message: <3d3c641e$1@news.povray.org>
lights.
Looks good so far.
You should still get the phong interaction with image_map if you specify it
in the finish.  The difference would be that you could have a different
phong value for the image and for the rest of the button with image_pattern.
If you are having dificulty getting the shape you want with CSG, you may
want to look at 'surface of revolution' or 'lathe'
-tgq
Date: 22 Jul 2002 16:01:08
Message: <3d3c6484@news.povray.org>
lights.
Looks okay. Could use some bump mapping to raise the imprints slightly so it
isn't absolutely flush with the button surface. Would need to reuse the
image in a normal statement as a bump_map (done like image_map in pigment
was) and make it negative bump_size I guess, otherwise you'll need a
negative color image.
Not sure of how much it matters but maybe something to try.
Date: 22 Jul 2002 16:13:34
Message: <3D3C6755.7020604@indecisions.org>
> lights.
> Looks good so far.
> -tgq
http://www.hostriot.com/072002/Buttons-2.png
I changed the cylinder getting cut by the sphere with the guy on it to a
superellipsoid object.  It allowed me to make a cylinder object with
rounded top.  Much easier and less code :-)
