POV-Ray : Newsgroups : povray.newusers : Placing objects on a height field Server Time
9 Oct 2024 14:23:08 EDT (-0400)
  Placing objects on a height field (Message 1 to 10 of 20)
Subject: Placing objects on a height field
Date: 22 May 2002 07:23:45
Message: <3CEB81F4.41BDB709@sympatico.ca>
Hi there,
  I was wondering if I put a height field as my ground, can I randomize
the placement of objects such as plants with relative elevation to the
HF?
I'm using povray 3.1 for linux...
Thanks,
  Simon
    "Neuromancer," the boy said.  "The lane to the land of the
dead.  Where you are, my friend.  I call up the dead.  But no,
my friend, I am the dead, and their land."    (William Gibson)
--  Simon Lemieux  (Rei### [at] Sympaticoca)
Subject: Re: Placing objects on a height field
Date: 22 May 2002 10:03:14
Message: <3ceba522@news.povray.org>
"Simon Lemieux" <Rei### [at] sympaticoca> wrote in message
news:3CEB81F4.41BDB709@sympatico.ca...
AFAIK, not with 3.1. You need trace which requires either megapov or 3.5.
On the other hand, if you use leveller, you have the option to export a series
of points on the surface iirc.
Date: 22 May 2002 22:03:05
Message: <3CEC5014.29F4E08E@sympatico.ca>
Doesn't anyone feel it's time to port the latest povrays to linux? ;)
I'll work my way around manually...  Thanks anyway!
Simon
Date: 23 May 2002 07:19:26
Message: <3cecd03e$1@news.povray.org>
news:3CEC5014.29F4E08E@sympatico.ca...
Why not give megapov a try?
I might be able to help via leveller - if you send me your scene file and the hf
image I could generate some points for you.
Date: 23 May 2002 09:32:28
Message: <3cecef6c@news.povray.org>
  Try http://povray.org
Date: 23 May 2002 10:43:07
Message: <3cecfffb$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3cecef6c@news.povray.org...
I assume Simon's after 3.5 (since he needs trace) - are 3.5 RC's avail. for
Linux? (I can't see 'em).
Date: 23 May 2002 11:58:58
Message: <3ced11c2@news.povray.org>
  Yes. Look closer.
Date: 23 May 2002 14:35:47
Message: <3CED38C6.2A2E336@sympatico.ca>
>   Yes. Look closer.
Indeed!  But I had a look in the download section before where it's
not.  But I could find the link to linux povray version 3.5.
  Thanks Warp!
PS: does the 3.5 has the isofunctions?
Date: 23 May 2002 15:49:42
Message: <3ced47d6@news.povray.org>
news:3CE### [at] sympaticoca...
>   Thanks Warp!
Yes - although the syntax is slightly different than for megapov. It's still
RC (release candidate), so there is an expiry date (but you probably knew
that).
Date: 23 May 2002 18:05:06
Message: <3ced6792@news.povray.org>
Have you tried Terraform?
It's a open source landscape/heightfield editor which runs under Linux. It
has the ability to place objects on landscapes and renders its output with
Pov-Ray 3.1
I managed to get it running under Mandrake 7.1 (after installing lots of
extra packages). Looking at the website I noticed that a new version has
appeared (version 0.9.0) which mentions "improved object placement".
See the following link for more details:
http://terraform.sourceforge.net
Reuben
doo### [at] breathemailnet
