POV-Ray : Newsgroups : povray.newusers : animation question Server Time
19 Dec 2025 18:45:11 EST (-0500)
  animation question (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: animation question
Date: 19 Jan 2002 12:00:35
Message: <3C49A6AF.4F4C8B8C@helix.nih.gov>
Michael DiDonato wrote:
>> Of course one could mention that there are macromolecular graphics
>> programs that support animation with povray in one form or other.
>> Hope this helps.
> Do you know of any?
VMD, Ribbons, Dino, pyMol and well glr ( shameless promotion of my
program :)
L.
Date: 19 Jan 2002 12:15:11
Message: <3C49AA1C.FE8A1D4@helix.nih.gov>
Deaken wrote:
> Chris Howie wrote:
> > rotate <0,clock,0>  // move clock into the desired axis
> That's the second time I've seen that particular rotate used in this
> thread.  Well, the first one was "rotate clock * y".  In neither case was
> there a Start_ or End_Clock mentioned.
> Am I a complete idiot for using "rotate <0, 360*clock, 0>", or did two
> people make the same mistake?  Both of these options?  Neither?
> Deaken (who has set followups, since this is not a unix question)
rotate clock * y is an alternative to rotate <0,clock,0> as y = <0,1,0> .
Yes and you are right that I did not mention start and end. I don't have the
exact commandline syntax or the stuff that you put in the .ini file in my
head right now which is why I said look it up in the manual. Of course if
you plan to have say n images with the first and last being identical one
should  use something like this
rotate clock * 360  / n * y   //  where clock goes from 0 to n. Unless I am
mistaken the user can assign any real value to clock and it will go from
start to end; so you can use integral values that match the frame number or
fractions from 0 to 1.  Talking so much about it I looked it up : the
command line switch is +k and in the .ini
file it would be clock=### where ### is a start value.  Look at povray 3.1
documentation like  pov115.htm#_Toc449951170.
L.
Date: 19 Jan 2002 12:27:24
Message: <chrishuff-143206.12281619012002@netplex.aussie.org>
In article <3C495FC2.470A0742@sw-tech.com>, Deaken <dwy### [at] sw-techcom>
That is actually probably the best way to do it...if you write all your
scenes to work with the default [0, 1] range, you will have an easier
time moving code between them. It could also get harder to control when
you modify the clock range.
It's probably a matter of personal prefrence, though making the clock
run from 0 to 360 just for a rotation seems like a bad idea...what if
you then want to add translation by 1 unit over the course of the
animation?
Date: 19 Jan 2002 13:48:04
Message: <3c49bf64$1@news.povray.org>
    No, yes, no, no.
Date: 19 Jan 2002 19:50:42
Message: <3c4a1462$1@news.povray.org>
"Deaken" <dwy### [at] sw-techcom> wrote in message
news:3C495FC2.470A0742@sw-tech.com...
If you're asking whether or not clock by itself will rotate 360 degrees,
then no.  Not necessarily anyway, unless you specify a Intitial_Clock=1 and
Final_Clock=360 for INI file.
If you asked if rotate clock * y is same as <0,clock,0> then the answer is
yes.  Or in your example, rotate 360*clock*y.
bob h
Date: 19 Jan 2002 20:12:21
Message: <3C4A19A2.115686BF@sw-tech.com>
Right.  I'm sorry, I was unclear in my question.  My point was not that the
individual x/y/z names are shorthands for the vectors, it was that some
people multiply by the clock, whereas I multiply by (the clock times 360).
In fact, I had originally written "y*360*clock", but changed it for the sake
of clarity.
The general form of what I use.  I am not good enough to generalize the
method and use clocks that are not simply 0-1.
Deaken
Date: 19 Jan 2002 20:16:39
Message: <3C4A1AA4.2AB969B9@sw-tech.com>
Actually, I was asking if my belief (that this was incorrect) was correct.
I think that means the same thing as what you said...
Deaken
Date: 20 Jan 2002 14:16:53
Message: <3c4b17a5@news.povray.org>
No, you're right.  It escaped me again.  360*clock IS correct.
Sorry about the error.
__________________
Chris Howie
cra### [at] yahoocom
http://winimizer.virtualave.net
Date: 20 Jan 2002 23:10:40
Message: <3C4B94F2.54415E25@sw-tech.com>
Oh, no need to apologize.  Being a rank amateur, I wanted to make sure that
I wasn't  doing something that merely LOOKED like it was working, or
overworking the problem (a major fault of mine), or something along those
lines.
Deaken
Date: 3 Mar 2002 23:21:47
Message: <3c82f65b@news.povray.org>
Try this:
http://www.mol.biol.ethz.ch/wuthrich/software/molmol/
d.
  "Michael DiDonato" <did### [at] scrippsedu> wrote in message
news:3C48BA7A.B612C665@scripps.edu...
    Not sure how your scene is  structured but one thing that comes to
mind
    would be to put all your objects into a union like
    union {
       sphere ...
       triangle ...
        //  up to here are your objects
       rotate  clock * y
    Read the part about animation in the manual of povray. There is a
clock
    variable that can be set and if you use povray's animation feature
this
    variable is increased
    with each new frame.
    Hope this helps.
     Lothar.
    Dr. Lothar Esser
    NIH / NCI
    Tel. 301-435-6163
    email les### [at] helixnihgov
  Do you know of any?
Michael DiDonato, PhD
The Scripps Research Institute
Department of Molecular Biology
Maildrop MB4
10550 North Torrey Pines Road
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
http://www.scripps.edu/~didonato
Download 'iso-8859-1' (3 KB)
