POV-Ray : Newsgroups : povray.newusers : Testing pictures of animation Server Time
10 Oct 2024 02:20:43 EDT (-0400)
  Testing pictures of animation (Message 1 to 5 of 5)
Subject: Testing pictures of animation
Date: 30 Nov 2001 09:17:35
Message: <3C0794BB.604598E0@radiok2r.de>
Hello!
I want to make an animation with different objects- and
camera-positions. Whats the best way to test siglne pictures out of the
animation? Okay, you could edit povray.ini and then redeclare the
animation-variables:
Initial_Frame = 10
Final_Frame = 10
Initial_Clock = 0.5
Final_Clock = 0.5
Is there a more comfortable way to do this?
Martin
Subject: Re: Testing pictures of animation
Date: 30 Nov 2001 09:31:16
Message: <3c079834$1@news.povray.org>
... maybe use the commandline-switch "+k" ....
after this you can specify the clockvalue ...
that's how I do it ...
Jan Walzer <jan### [at] lzernet>
Date: 30 Nov 2001 12:17:31
Message: <3c07bf2b@news.povray.org>
"Martin Thoma" <mar### [at] radiok2rde> wrote in message
news:3C0794BB.604598E0@radiok2r.de...
> Initial_Frame = 10
> Final_Frame = 10
> Initial_Clock = 0.5
> Final_Clock = 0.5
I either use a custom ini file which has:
Subset_Start_Frame=10
Subset_End_Frame=10
along with the usual stuff and leave it in the editor while I make changes.
If you wanted to go with command line instead they would be +sf10 +ef10.
You can even choose to use a fraction, or percentage, of the whole by using
numbers 0.0 to 1.0
Date: 30 Nov 2001 13:30:40
Message: <3C07D051.2E3C144@spiritone.com>
Martin Thoma wrote:
> Hello!
> Initial_Frame = 10
> Final_Frame = 10
> Initial_Clock = 0.5
> Final_Clock = 0.5
> Martin
I usually replace the clock variable in various places in my script.
#declare Camera_Clock = 0; // or any value, or clock
then I can render any moment in time of my animation without turning
animation on.
SInce I tend to manipulate the clock variable a lot in an animation,
this works best for me.
Josh English
Date: 30 Nov 2001 13:45:32
Message: <3C07D47B.540FA855@hotmail.com>
Martin Thoma wrote:
> Hello!
> the animation? Okay, you could edit povray.ini and then redeclare the
> Initial_Frame = 10
> Final_Frame = 10
> Initial_Clock = 0.5
> Final_Clock = 0.5
> Martin
I use three .INI files:
final.ini is for doing final renderings (antialiasing on, pic size is
  320x240)
still.ini is for doing tests of individual shots (antialiasing is off,
  pic size is 512x384)
test.ini is for animation tests (antialiasing is off, pic size is
  320x240)
This makes it easy to stop the final rendering when I get the machine
back from the wife, do some modelling, some test renders, and then
resume the final rendering where I left off, when I go to bed.
John
ICQ: 46085459
