POV-Ray : Newsgroups : povray.newusers : Interior of a Beer glas Server Time
12 Feb 2026 17:14:17 EST (-0500)
  Interior of a Beer glas (Message 1 to 10 of 10)
Subject: Interior of a Beer glas
Date: 6 Apr 2001 08:08:08
Message: <3ACDB1CE.6EE82243@exmail.de>
i`ve modeled a beer glas with moray, using a rotational sweep. Now i
want to fil it with something, beer for instance ;). Do i have to model
the correct counterpart of the interior of the glas and give it the
desired texture, or is there an easier way to do this? As far as i know,
csg doesn`t work with this kind of objects (sweeps).
Hope, this is the right group, I think it is not moray specific.
best wishes,
Robert
Subject: Re: Interior of a Beer glas
Date: 6 Apr 2001 10:09:08
Message: <3ACDCE2A.152D5EE6@exmail.de>
See picture in p.b.i
Robert
Date: 6 Apr 2001 12:33:07
Message: <3acdefc3$1@news.povray.org>
news:3ACDB1CE.6EE82243@exmail.de...
Is the shape a lathe, a SOR or something else?
If a lathe, then just fill it with a smaller copy of the same object after
differencing out the stem.
Not sure about SORs (or "something else" needless to say).
Date: 6 Apr 2001 12:35:21
Message: <3acdf049@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3acdefc3$1@news.povray.org...
... woops, misleading advice. You will need a solid version of your glass. I
would suggest editing a copy of your glass by hand in pov (assuming it's a
lathe).
Date: 6 Apr 2001 13:47:39
Message: <chrishuff-53C71C.12474006042001@news.povray.org>
In article <3ACDB1CE.6EE82243@exmail.de>, Robert Gunther
If Moray outputs a sor or lathe object for its "sweep", CSG will work
fine.
Christopher James Huff
Date: 6 Apr 2001 19:12:31
Message: <3ace4d5f$1@news.povray.org>
> Hi,
> i`ve modeled a beer glas with moray, using a rotational sweep. Now i want
> to fil it with something, beer for instance ;). Do i have to model the
> correct counterpart of the interior of the glas and give it the desired
> texture, or is there an easier way to do this? As far as i know, csg
Couldn't you make a copy of your glass object, and then edit the contour
spline, i.e. removing all part except the inner surface that in the case of
wine would touch the glass. Then you could add a "cap" to this trimmed
object and voila, you should have your wine! Next you should scale the wine
object either a bit larger or smaller so it doesn't coincide with the glass
surface (I've found that scaling it slightly bigger gives more realistic
effects).
I can't test this in moray, but I've done it with other modelling packages
and hand-coded POV, so in principle it works.
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 7 Apr 2001 06:39:43
Message: <3ACEEE97.1921C777@exmail.de>
> effects).
> Margus Ramst
Thanks, Margus,
that`s the way i've done it now and it seems to work. Rendering is very, very
slow :(
Robert
Date: 7 Apr 2001 06:40:56
Message: <3ACEEEE0.ED35F526@exmail.de>
Sorry, but what is SOR?
BTW, moray exports the sweep as triangle raws.
Robert
Date: 7 Apr 2001 13:13:05
Message: <3ACF4AC8.4CCC276D@exmail.de>
Oops, have to read the manual a little bit more often.
SOR: surface of revolution
I apologize,
Robert
Date: 7 Apr 2001 18:25:29
Message: <3acf93d9$1@news.povray.org>
> Thanks, Margus,
> very slow :(
It's supposed to be, I'm afraid... Multiple nested transparent & reflecting
surfaces are that way.
Margus Ramst
