POV-Ray : Newsgroups : povray.newusers : Turning off povray's finish beep? Server Time
23 Dec 2025 18:58:20 EST (-0500)
  Turning off povray's finish beep? (Message 1 to 8 of 8)
Subject: Turning off povray's finish beep?
Date: 2 Mar 2001 11:30:25
Message: <3A9FCAA1.F94AFD5A@gmx.de>
Anyone who knows how to do it?
I could not find where, probably i'm just too dumb, my cygwin version even
uses the speaker and not the sound card so i can't even turn the volume
down.
The VFAQ suggests '-p', but that does not work.  Previous threads in this
group concerning this problem also did not help.  Any other command line
option or position in source code would help.
Subject: Re: Turning off povray's finish beep?
Date: 2 Mar 2001 17:16:05
Message: <3AA01B2F.5F6A0D59@faricy.net>
Windows? "Render" -> "On Completion" -> ...
Date: 27 Jul 2001 12:21:10
Message: <3B61B1EC.6030804@nospam>
This is taken from the Pvengine.INI file.
[Renderer]
AlertSound=64
Completion=2255
Priority=2305
AlertOnCompletion=1
AutoRender=1
NoShelloutWait=0
SystemNoActive=0
Where you see ----AlertSound=64-----64 is the sound file used.
                        ----AlertOnCompletion=1------1 should be
"true"(ON) and 0 should be "false"(OFF). If you set this value to 0 it
should turn the beep off. Always make a backup of  files such as this
just in case, before making changes.
> down.
> Christoph
Date: 27 Jul 2001 12:58:26
Message: <slrn9m37dk.qo6.ron.parker@fwi.com>
Which, if you mess with it and you break something, you get to keep both
pieces of.  Did you fail to notice the Render/On Completion/Do nothing
menu item?  What do you suppose that does?
Besides, the question you quoted was about a command-line version, which
won't use pvengine.ini anyway.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 27 Jul 2001 13:04:41
Message: <3B61BC1F.3090509@nospam>
Gee Ron,
I must have missed that. Oh well some of us still do make mistakes.....:)
Download 'us-ascii' (1 KB)
Date: 27 Jul 2001 13:06:03
Message: <slrn9m37rt.qo6.ron.parker@fwi.com>
Assuming you're basing your cygwin version on the MS-DOS source, try
searching for the word "beep" in msdosvid.c and commenting out that line.
If you're starting with the unix source, I'm afraid I don't have a file
name, but you might try grepping the OS-specific stuff for "\007"
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 27 Jul 2001 13:10:06
Message: <slrn9m383g.qo6.ron.parker@fwi.com>
On Fri, 27 Jul 2001 12:08:15 -0700, nospam@nospam wrote:
>Gee Ron,
Say it ain't so!
Well, at least you brought some attention to this (really old, btw) post
that had never been satisfactorily answered.
>--------------030803030303000409000504
>Content-Type: text/html; charset=us-ascii
Could you not make this particular mistake (posting in both text and HTML)
again?
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 27 Jul 2001 13:16:29
Message: <3B61A264.E771C920@gmx.de>
Yes, meanwhile this is already found:
news://news.povray.org/3b4268f3%40news.povray.org
