POV-Ray : Newsgroups : povray.newusers : not really a raytraing question but... Server Time
11 Apr 2026 07:17:31 EDT (-0400)
  not really a raytraing question but... (Message 1 to 8 of 8)
Subject: not really a raytraing question but...
Date: 3 Jan 2001 19:51:12
Message: <3A53CA23.50C40EE9@aol.com>
would be most grateful for the answer...
I am running compiles in DOS from the "dosprompt" or "consol" that W98
provides and I want to stream the compiler errors, which are normally
written to the consol, to a file instead.  I know I used to do this once
upon a time, but cannot remember what the switch is and cannot seem to
turn it up in any books I have.  Can anyone be so kind ...
jc
Subject: Re: not really a raytraing question but...
Date: 3 Jan 2001 20:07:53
Message: <3A53CD07.B6260670@pacbell.net>
> jc
Just use  " > "  at the end of your command line to pipe it to a .txt file
dir c: /s > c_drive.txt
If you want to append it to an existing file use the following -
dir d: /s >> c_drive.txt
Ken Tyler
Date: 3 Jan 2001 20:39:04
Message: <3A53D558.F24E6A92@aol.com>
Thanks Ken,
I remembered it being something like that
but sadly, it ain't happening.  Maybe I am misunderstanding your answer.  what
does the /s do?
Would the OS matter?
> > jc
> Ken Tyler
Date: 3 Jan 2001 20:51:21
Message: <slrn957lot.biv.ron.parker@fwi.com>
I don't think there's a way to do it in command.com.  If you were using
NT's cmd.exe, you could just add "2>errors.txt" to the end of the command
line.
If you're using cygwin, you might try using the bash shell that comes with
it and using the same 2> notation to redirect stderr.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 3 Jan 2001 21:18:10
Message: <3A53DD80.A916CE00@pacbell.net>
J Charter wrote:
> Thanks Ken,
> does the /s do?
Like Ron said it may not work as expected. The "dir" command
I used was just an example usage of the " > " symbol and the
/s is used by the dir command to search subdirectories. Since
I don't know the command line operation you were using I
couldn't provide an exact example usage of it.
Date: 3 Jan 2001 21:30:34
Message: <slrn957o2d.bj7.ron.parker@fwi.com>
On Wed, 03 Jan 2001 18:18:40 -0800, Ken wrote:
>J Charter wrote:
>> Thanks Ken,
>> does the /s do?
">>" redirects standard output (with append, but that's irrelevant), and most
compilers (C compilers, anyway) put errors on standard error.  Command.com
doesn't have a facility for redirecting standard error, unfortunately.
Date: 3 Jan 2001 21:50:28
Message: <3A53E617.52D60E2@aol.com>
ahhhh   Thankyou for at least restoring some recognizable landmarks,  I
remember now did have it working once using 2>
under NT.  It is javac I am trying to run btw.  I guess that means that javac
IS going to stderr.  It is in the NT
environment at work that it matters most so thankyou much!  Whether I can do
it at home under W98 matters less.
> line.
Date: 4 Jan 2001 02:44:31
Message: <3aa85t0div5sj65kgv8t3gfmmqtro5p39c@4ax.com>
On Wed, 03 Jan 2001 19:56:03 -0500, J Charter <jrc### [at] aolcom>
See "Directing Text Streams to Files" in the POV-Ray documentation.
Peter Popov ICQ : 15002700
