Is there a way to use two different cameras and when you render you will get
POV-Ray will only allow you to use one camera at a time. If you need
seperate views then you will have to render more than one image using
different camera locations.
Using the animation system (clock), you could
switch between the camera definition
(have a look at #switch/#range/#case/#break/#end)
Then you get differents pictures with different names.
(scene1.png, scene2.png and so on)
But you will render the image for each camera !
: Is there a way to use two different cameras and when you render you will get
And how would the views be organized on the final image?
Each one taking a half of the image? Superimposed?
