POV-Ray : Newsgroups : povray.newusers : Text Question Server Time
22 Nov 2025 05:14:18 EST (-0500)
  Text Question (Message 1 to 9 of 9)
Subject: Text Question
Date: 19 Sep 2000 11:21:59
Message: <39c78497$1@news.povray.org>
Is there any way to make Text objects be rounded instead of flat?
Subject: Re: Text Question
Date: 19 Sep 2000 12:15:25
Message: <39c7911d@news.povray.org>
"Tyler Eaves" <tyl### [at] tylereavescom> wrote in message
news:39c78497$1@news.povray.org...
Pick a rounder font? Oh, you mean the front/edges/whatever... Hmm, well if
you use megapov, you could use trace to place blobs appropriately. I think
there have been some examples of this in binaries.images.
My entry in the ocean irtc (tmstormc) used a similiar approach to lay the
gold rim around the top of the cup.
You could also try creating an intersection of a blob and a letter, with the
blob wider but shallower than the letter (ie. the face of the letter should
stick up out of the blob, but be entirely surrounded by blob).
Date: 19 Sep 2000 16:06:40
Message: <oY6BbLArm6x5EwxX@econym.demon.co.uk>
Matthew Edd Tillman (mrh### [at] usanet) has produced a macro that
generates nice rounded text made from CSG bits of torus. If it's not on
his web site (http://www.bigfoot.com/~special_edd) you could try a web
search for "rchar.inc".
Mike Williams
Gentleman of Leisure
Date: 19 Sep 2000 16:22:27
Message: <fgifsssu1eg70pb3gseba6rjhip6nm7mf8@4ax.com>
On Tue, 19 Sep 2000 11:21:50 -0400, "Tyler Eaves"
If you're working under Windows, search the links on povray.org for a
program called Elefont, it is really great at doing bevels and
extrusions and such on fonts, real-time previews included.
Peter Popov ICQ : 15002700
Date: 19 Sep 2000 16:49:16
Message: <slrn8sfi16.v54.steve@zero-pps.localdomain>
Try SoftText at Rune's site, http://rsj.mobilixnet.dk it lets you
chose the text you want and then select the size and roundedness
IIRC,  it also has capabilities for wrapping text around objects
etc.
  9:06pm  up 29 days,  1:19,  2 users,  load average: 1.25, 1.11, 1.03
Date: 19 Sep 2000 16:54:25
Message: <chrishuff-D8A98E.15562719092000@news.povray.org>
In article <39c7911d@news.povray.org>, "Tom Melly" <tom### [at] tomandlucouk>
> well if you use megapov, you could use trace to place blobs
> appropriately. I think there have been some examples of this in
> binaries.images.
If you are talking about the macro I made, it didn't use trace(), it
used the eval_pattern() function with the object pattern to put a bunch
of blob components inside the text object.
Christopher James Huff
Date: 19 Sep 2000 21:25:15
Message: <39C8114D.9CFB8862@pacbell.net>
> etc.
ALERT !!! ALERT !!! ALERT !!! ALERT !!!
SoftText is Remco De Korte's program and can be found instead at:
http://www.xs4all.nl/~remcodek/softtext.html
Date: 19 Sep 2000 22:00:02
Message: <B5ED6877.23A4%davidmccabe@mac.com>
Hmm... I would try using height fields, in the same way as in "spiral".
> From: Ken <tyl### [at] pacbellnet>
> Organization: Tyler Engineering Services
> Reply-To: lin### [at] povrayorg
> Newsgroups: povray.newusers
> Date: Tue, 19 Sep 2000 18:22:21 -0700
>> etc.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 19 Sep 2000 22:15:53
Message: <slrn8sg5tu.9f.steve@zero-pps.localdomain>
>> etc.
I knew it was three words, and the first one began with R.
Sorry :-)
>http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
  2:44am  up 29 days,  6:57,  2 users,  load average: 1.03, 1.09, 1.04
