POV-Ray : Newsgroups : povray.newusers : Curving cylinders and cones? Server Time
13 Feb 2026 02:43:08 EST (-0500)
  Curving cylinders and cones? (Message 14 to 23 of 23)
Subject: Re: Curving cylinders and cones?
Date: 3 Oct 2000 21:12:39
Message: <39DA845A.C594FF0@yahoo.com>
> I'd say make a script to generate triangle meshes, use isosurfaces (requires MegaPOV
from
> nathan.kopp.com), or (for the cylinders only) a torical section; if you need math
help let
> me know.
Yes this is good, I would actually make a C++ program for this, as I usually
do...
But,  I forgot to say about interior...  it is being discussed in
povray.advanced-user and as I know a bunch of triangles togheter won't have a
proper interior... which will be important as soon as I get a curver cylinder,
this is my next step, I forgot to mention it...
I think the best way to do it is still to put a few cylinders togheter and curve
them myself...  the junction could be made with an intersection of the two
segments and the union of the two segments themselves, etc...
What do you think?
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Date: 3 Oct 2000 23:51:27
Message: <39DAA6ED.79B2344D@faricy.net>
You mean paste together cylinder sections? Tori section would have infinite resolution
and
render fast... and isosurfaces give you the ultimate control, you give it a function
and it
renders the implicit surface...
Date: 4 Oct 2000 13:31:43
Message: <39DB69DB.1ACD94@yahoo.com>
resolution and
and it
Tori sections is a good idea, but what for a cone?  There I would need cone
sections...
But I've never used/read-about isosurface before, do they have interior?  Could
you send me a picture url that would describe this in a word?  And is it in the
manual of povray, or, where could I get more information about isosurface?
Date: 4 Oct 2000 17:37:13
Message: <chrishuff-638F8D.16384504102000@news.povray.org>
> need cone sections...
To do that you would have to use isosurfaces...fortunately, the function
to do that shape would be pretty simple and fast rendering, just vary
the minor radius of a torus function with angle.
They are ordinary solid objects, so they can be used as media containers
and work fine in CSG.
> Could you send me a picture url that would describe this in a word?
A picture? An isosurface can do nearly every primitive in POV-Ray, and
many other shapes.
Basically, you supply an equation that gives a value based on xyz
coordinates. The isosurface is the surface formed by all points where
your function is equal to a certain threshold value.
There are several tutorials online, but I don't have the URLs handy for
any of them right now...they would be on the links page at povray.org
though.
> And is it in the manual of povray, or, where could I get more
They are not in the official version yet, but they are included in
MegaPOV, an unofficial version.
http://nathan.kopp.com/patched.htm
Christopher James Huff
Date: 4 Oct 2000 21:43:42
Message: <39DBDD2E.15E69727@yahoo.com>
Oh... I see, I've heard Povray 4 will be released soon or has already been
released?  Will it contain the isosurfaces?  I'll check out for MegaPov...
Thanks
Date: 4 Oct 2000 23:08:32
Message: <39DBEFAB.A8104528@pacbell.net>
POV-Ray v3.5 will be released (relatively) soon and will offer
isosurfaces. POV-Ray v4.0 is a mere twinkle in the POV-Team's
eye at this point in time.
Date: 5 Oct 2000 06:55:44
Message: <39dc5e2f@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: An isosurface can do nearly every primitive in POV-Ray, and
: many other shapes.
  Good that you said "nearly" because isosurfaces can't do _every_ primitive
in povray.
  Quiz: Which primitive or primitives it can't create at all?
        Which primitive or primitives it can create only partially?
Date: 5 Oct 2000 09:23:34
Message: <slrn8tp06t.k3i.ron.parker@fwi.com>
>in povray.
Among others, julia and mesh.  (Well, mesh might be possible but it would be
ugly.)
planes, polys, anything infinite.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Proudly not helping RIAA and SDMI steal my rights --
  http://www.eff.org/Misc/EFF/Newsletters/EFFector/HTML/effect13.08.html
Date: 5 Oct 2000 09:52:26
Message: <39dc879a@news.povray.org>
MegaPOV from
help let
>> me know.
> do...
> What do you think?
I think a sphere sweep might be your perfect solution.  Assuming you can
compute the points that the cylinder begins and ends and intermediate
points, this will give exactly the effect you want if you use one of the
splines.  Even if you don't use a spline function, it should be cleaner than
using a lot of cone segments as the edges won't be visible.
Best of all, since each has a radius, it'll work for your cones too.
And finally, you won't have to do a merge to get rid of internal surfaces,
since the sweep would be a single object.
Geoff
Date: 5 Oct 2000 12:57:03
Message: <39DCB298.ABEA6C93@inapg.inra.fr>
For the record, here is a croissant-making isosurface I posted in p.advanced-users
some time ago.
#declare major_axis=5;
#declare minor_axis=1;
#declare a=function{sqrt(x^2+z^2)-major_axis}
isosurface{
    function{sqrt(y^2+a^2)-minor_axis*(0.9+z*0.2)}
    contained_by{sphere{0,10}}
    eval
    threshold 0
    pigment{Red}
    rotate y*45
G.
