POV-Ray : Newsgroups : povray.newusers : Calling 'procedures' with variables? Server Time
10 Oct 2024 04:14:36 EDT (-0400)
  Calling 'procedures' with variables? (Message 1 to 6 of 6)
Subject: Calling 'procedures' with variables?
Date: 29 Aug 2000 17:10:53
Message: <39AC2738.5D9668D1@istar.ca>
I've created a pigment type which depends on a variable, n. If I
#declare n before the pigment code, it runs correctly.
However, I would like to be able to call this pigment type many times,
with different values of n. I thought that I could simply remove the
#declare before the pigment code, and use the code like:
texture { #declare n=1
              PigmentName
texture { #declare n=2
              PigmentName
However, POV complains that n is undefined when it first encounters the
code.
How can I use the pigment code as a procedure, called with the variable?
I've tried #macro, but haven't gotton anything working.
Thanks!
Simon
Subject: Re: Calling 'procedures' with variables?
Date: 29 Aug 2000 17:33:41
Message: <chrishuff-C8E47D.16351429082000@news.povray.org>
You aren't "calling a pigment type", you are creating a copy of a
variable which has already been parsed.
The macro feature is what you want. Just wrap the pigment definition in
a macro statement and use the parameters to specify your variables. What
were you trying to do?
#macro Radial(Rays, ClrA, ClrB)
    pigment {radial
        frequency Rays
        color_map {
            [0 color ClrA]
            [1 color ClrB]
Christopher James Huff
Date: 29 Aug 2000 21:16:38
Message: <39AC60D1.D4A0E968@istar.ca>
>     pigment {radial
>         frequency Rays
>         color_map {
>             [0 color ClrA]
>             [1 color ClrB]
> #end
I'm using something nearly identical, but it is still not working.
My code is of the form:
#macro PigmentFunc (n)
    #declare Pigment = pigment { bla bla n bla bla }
I then try to call it by using:
PigmentFunc (0.5)
texture {Pigment}
However, Pov still complains when it gets to the first line of the code which
contains the n variable, saying "numeric expression expected but undeclared
identifier 'n' found instead."
Am I missing something fundamental here? Would there be any benifit in my
posing the code?
Simon
Date: 29 Aug 2000 22:58:42
Message: <39AC7863.E2C82923@yahoo.com>
some single letters have been taken over by megapov as reserved words.
try making n a real word like my_n_variable to eliminate the possiblity
of conflict.
> > #end
> > PigmentFunc (0.5)
> > texture {Pigment}
> I take it you tried:
> n=0.5;
> PigmentFunc(n)
Date: 30 Aug 2000 09:38:35
Message: <chrishuff-8621C7.08400930082000@news.povray.org>
> code which contains the n variable, saying "numeric expression
> expected but undeclared identifier 'n' found instead."
This sounds like a typo somewhere. Make sure you use an upper-case
letter in all variables to avoid conflicts with keywords, and make sure
you use the same variable name in the pigment as you used in the macro
parameter list.
Try something more like this:
texture {PigmentFunc(0.5)}
You can also use the macro to declare a pigment, like this:
#declare MyPigment = PigmentFunc(0.35)
> Would there be any benifit in my posing the code?
It would help us to find what exactly is wrong with it, but you seem to
be doing it in a round-about way, you might want to completely change
the way you are doing it.
Date: 30 Aug 2000 15:35:59
Message: <izezRGATvRr5Ewzm@econym.demon.co.uk>
>#end
>PigmentFunc (0.5)
>texture {Pigment}
>posing the code?
The problem is somewhere else, in part of the code that you're not
describing. The syntax you describe above works perfectly for me, e.g.
  #declare Pigment = pigment{rgb <n,n,0>}
PigmentFunc (0.2)
sphere{-x,1
 texture{Pigment}
PigmentFunc(0.5)
sphere{0,1
 texture{Pigment}
PigmentFunc(0.9)
sphere{x,1
 texture{Pigment}
Works perfectly, though it might have been simpler to code it more like
this:-
#macro PigFun (n)
  rgb <n,n,0>
sphere {y,1 texture{pigment{PigFun(0.1)}}}
sphere {-y,1 texture{pigment{PigFun(0.9)}}}
Are you using the official POVRay, or MEGAPov? There can sometimes be
strange behaviour in MEGAPov in the following circumstances:
  If you declare a #macro inside a #while loop.
  If you declare one #macro inside another #macro declaration.
Mike Williams
Gentleman of Leisure
