POV-Ray : Newsgroups : povray.newusers : saving generated images Server Time
19 Jun 2026 09:37:34 EDT (-0400)
  saving generated images (Message 1 to 8 of 8)
Subject: saving generated images
Date: 7 Aug 2000 18:05:57
Message: <398f32c5@news.povray.org>
I know that POV-ray saves the .bmp, or .png files of rendered scenes in
the directory of the original .pov files.  I also know how to create a
default folder for images.  But is there a way to get POV-ray to prompt
me where to save the image every time I render a scene?  Or can I make
it work like bCAD: render the scene without saving the image and let me
decide whether to save it as a file or not.
Subject: Re: saving generated images
Date: 7 Aug 2000 19:46:06
Message: <slrn8oui9d.p89.steve@zero-pps.localdomain>
I'm using linux, and in my equivelant of the ini file I have a setting
Output_to_File=true I'm sure that you have the same sort of thing over
there that you can put in your povray.ini file and set to false.
Just try the pasting the keyword from above and see if it works.  And
then there's always the good old documentation which comes with POV and
if that fails you your question may be answered in Warp's VFAQ at:
http://iki.fi/warp/povVFAQ/
I'm sure a windows bod will be along in a minute and give you a better
answer than myself.
 12:32am  up 23 days, 22:58,  2 users,  load average: 2.10, 1.58, 1.36
Date: 7 Aug 2000 22:02:34
Message: <398F5C34.330CD2CB@peak.edu.ee>
I assume you use POVWin, in which case you could create an INI file similar to
quickres.ini (the one that lets you pick resolutions via the GUI dropdown list).
See the quickres file an ini file documentation for syntax info, it's really
straightforward. Something like:
[First directory]
Output_File_Name=c:\blah\first_directory\
[Second directory]
Output_File_Name=c:\bleargh\second_directory\
Then you select your ini file in the render settings menu and the dropdown list
should contain your choice of directory destinations.
Margus Ramst
Date: 8 Aug 2000 05:42:21
Message: <398fd5fd@news.povray.org>
Kaganovich <kag### [at] flashcomnet> wrote:
: But is there a way to get POV-ray to prompt
: me where to save the image every time I render a scene?
  That would be a real pain in the a** when doing test renders...
  Why do you want to do this? It shouldn't matter whether povray saves the
image or not.
Subject: why I want to do this
Date: 8 Aug 2000 14:49:05
Message: <39905613.D9816BA7@flashcom.net>
> image or not.
Well, I often make an image, change the file slightly, and want to make a new
image, but the new image replaces the old one, so I have to manually rename
the first image or move it to a different folder; or I have to rename the file
after minor changes. For example, if I want to get different views, I may
simply change the camera angle. But that's why ideally for test renders, I
would like POV-ray not to save the image at all until I first look at it and
request that it gets saved.
Subject: Re: why I want to do this
Date: 9 Aug 2000 05:31:43
Message: <399124ff@news.povray.org>
: Well, I often make an image, change the file slightly, and want to make a new
: image, but the new image replaces the old one, so I have to manually rename
: the first image or move it to a different folder; or I have to rename the file
: after minor changes.
  You can change the name of the output image using the command line
parameter +O.
  In Winpov, use alt-c to get that field quickly (was it alt-c? I'm not sure
anymore; anyways, you can see the shortcut in the proper menu anyways).
Subject: Hey, it worked
Date: 9 Aug 2000 20:08:13
Message: <3991F25F.CFD81E28@flashcom.net>
> parameter +O.
Excellent well. Yeah, y'all assumed correctly that I use WinPov 3.1, and the
shortcut is indeed alt-c, though there's a button in a toolbar to bring up the
field.  At least now I can decide whether I want to save my generated images under a
different name. Thanks for the help.
p.s. If anyone's got even better suggestions, such as how to test render without
saving, I'm still open to them.
Subject: Re: Hey, it worked
Date: 9 Aug 2000 20:18:45
Message: <3991f4e5@news.povray.org>
without
That's command-line switch  -F
