POV-Ray : Newsgroups : povray.newusers : Light question Server Time
22 Mar 2026 15:59:02 EDT (-0400)
  Light question (Message 1 to 7 of 7)
Subject: Light question
Date: 18 Jul 2000 13:54:31
Message: <397499d7@news.povray.org>
seen in the mirror ( lightsource in the middle of the
room looks very unrealistic) Is there a way to use
work well, and I need  light for the walls too. ( because
I hope you can help
Subject: Re: Light question
Date: 18 Jul 2000 14:05:30
Message: <39749B14.6E7EF438@pacbell.net>
Have you actually tried using a light_source to see the results ?
In POV-Ray light_sources are not visible to the camera. Because
of this they should not be visible in the mirror either.
Date: 18 Jul 2000 14:46:37
Message: <3974a60d@news.povray.org>
was a bright point on the wall behind the camera. It was
very confusing, moving the lightsource and seeing this
bright point in the mirror moving too.
Thanks anyway
Another question. How can I avoid this bright point on the
from stoneold.inc )
Date: 18 Jul 2000 14:50:44
Message: <3974A5AF.30FF30A5@pacbell.net>
> from stoneold.inc )
It sounds like phong highlighting in the finish statement. That
is usually the source for spots like that. You may need to make
a custom finish for your particular application.
Date: 18 Jul 2000 15:04:59
Message: <3974aa5b@news.povray.org>
It is really the phong, seems to be normal for this texture.
I have to use phong_size 500000 to hide the spot.
Date: 18 Jul 2000 15:07:20
Message: <3974A993.693A4325@pacbell.net>
You can also lower the phong number instead of the phong_size to
influence it's affect on the finish i.e phong 0.25 phong_size 200
Date: 18 Jul 2000 15:13:48
Message: <3974ac6c@news.povray.org>
two days now )
Thanks for your help.
