POV-Ray : Newsgroups : povray.newusers : Normals in Pov Server Time
14 Jun 2026 18:23:04 EDT (-0400)
  Normals in Pov (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Normals in Pov
Date: 18 Jul 2000 08:08:20
Message: <397448AD.E69AF8D7@erols.com>
Warp wrote:
> John VanSickle <van### [at] erolscom> wrote:
> : For flat triangles the normal is derived from a cross-product of two
> : of the edge vectors (I presume) and therefore depends on the order
> : the vertices are defined.
>   I think it doesn't matter which side the normal is pointing to (as
> in any other surface in povray). This specially doesn't matter with
> triangles since they do not have interior.
I tested this and it seems you're right; my memory is playing tricks on
me again.
John
Date: 18 Jul 2000 11:12:45
Message: <chrishuff-6D2AB9.10131618072000@news.povray.org>
In article <3974264c@news.povray.org>, Warp <war### [at] tagpovrayorg>
> : of the edge vectors (I presume) and therefore depends on the order the
> : vertices are defined.
>   I think it doesn't matter which side the normal is pointing to (as in
John VanSickle is right, the normal is derived using the cross-product
of the edge vectors.(or something like that) The "up" side of the
triangle is determined by the order of the vertices.
For lighting calculations, the normal is always flipped so it points to
the side the intersecting ray came from, so you don't notice a
difference. However, the real normal does matter if you are using
MegaPOV and interior_texture. I am not aware of any other places where
it matters...
Date: 18 Jul 2000 13:22:22
Message: <JtjZGBA4F$c5Ewux@econym.demon.co.uk>
Wasn't it Warp who wrote:
>Jason Miller <jas### [at] pinheirotcimetnet> wrote:
>: Does Povray care about the winding of a mesh?  As in, does it use 1 sided or
>: 2 sided polygons?  If it uses one sided, how can this be set to 2 sided?
>  I suppose that a 1-sided polygon is (like, for example, in OpenGL) a polygon
>that is seen only from one side. If the polygon is turned so that the other
>side faces the camera, then it's not rendered.
>  Povray only uses 2-sided polygons (ie. they are rendered now matter how they
>are rotated). I don't know of any plans of adding support for 1-sided polygons
>to povray (I'm not even sure how easy it is to make in raytracing).
I believe that 1-sided polygons are not possible in the current official
version of POVRay, but they can be achieved in MEGAPov by usng the
"interior_texture" keyword.
Every surface is considered to have an interior and an exterior (but
it's not always obvious which is which) and the interior_texture keyword
allows you to have a different texture on the two sides. If you make one
of these textures completely invisible {pigment {rgbt <1,1,1,1>}} then
you've got a 1-sided surface.
Mike Williams
Gentleman of Leisure
Date: 18 Jul 2000 18:58:35
Message: <3974E13A.49899E8C@erols.com>
> > : two of the edge vectors (I presume) and therefore depends on the
> > : order the vertices are defined.
> to the side the intersecting ray came from, so you don't notice a
> difference.
This is what I tested; the normal does indeed need to be flipped to
achieve this effect.  I'm fairly sure this was done in a recent
version of POV-Ray; I distinctly remember having to reverse the order
of some defined points in order to get the normals pointed the right
way.
John
ICQ: 46085459
Date: 18 Jul 2000 22:22:40
Message: <chrishuff-0591C5.21231018072000@news.povray.org>
In article <3974E13A.49899E8C@erols.com>, John VanSickle
> way.
I think the bug fix was added in 3.1b along with some double-illuminate
stuff:
"Fixed average normal bug and other normal flipping problems"
(revision.doc)
Date: 19 Jul 2000 04:50:24
Message: <39756bd0@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: I think the bug fix was added in 3.1b along with some double-illuminate
: stuff:
: "Fixed average normal bug and other normal flipping problems"
  But flipping the normal vector of a (non-smooth) triangle is NOT a bug! It's
the right behaviour.
  Think about a plane { y, 0 }. If you put a light source at y*10 it will
illuminate the top of the plane and the bottom will be shadowed. If you put
the light source at y*-10, it will be the other way around.
  Now, this same behavior has to happen with regular triangles as well. If
the light source is at one side of the triangle, that side has to be
illuminated and the other shadowed. It doesn't matter which side.
  To achieve this, the normal vector has to be flipped to point to the side
where the light source is. If the normal vector were pointing to the wrong
side, the side of the triangle which is facing the light source would be
shadowed, which is the wrong result.
Date: 19 Jul 2000 08:23:39
Message: <39759DCA.E0B64DE7@erols.com>
> : stuff:
> bug! It's the right behaviour.
> will illuminate the top of the plane and the bottom will be shadowed.
> If you put the light source at y*-10, it will be the other way around.
I was speaking of the calculations for normal patterns; the behavior
does seem to have changed since the 3.0 days.
John
Date: 19 Jul 2000 10:42:00
Message: <chrishuff-AB58C8.09423219072000@news.povray.org>
In article <39756bd0@news.povray.org>, Warp <war### [at] tagpovrayorg>
> : stuff:
Umm, that's why it was added. Flipping the normal is the bug fix I was
talking about. Before, it wasn't done, and sometimes caused problems. :-)
Date: 20 Jul 2000 05:56:42
Message: <3976ccd9@news.povray.org>
: Umm, that's why it was added. Flipping the normal is the bug fix I was
: talking about. Before, it wasn't done, and sometimes caused problems. :-)
  Oh, sorry. I got confused.
Date: 21 Jul 2000 16:20:48
Message: <chrishuff-A46E70.15212321072000@news.povray.org>
In article <39759DCA.E0B64DE7@erols.com>, John VanSickle
There have been changes...and wasn't there a limitation on what patterns
could be used as normals in the 3.0.x versions? I think some of those
changes had to do with allowing any pattern to be used.
Anyway, there will be even more changes...check out MegaPOV for a
"preview" of what 3.5 should be like. Most of the changes have to do
with making the normal scale more reasonably, they now act much more
like actual surface deformations would.
