POV-Ray : Newsgroups : povray.newusers : Normals in Pov Server Time
21 Mar 2026 20:01:08 EDT (-0400)
  Normals in Pov (Message 11 to 16 of 16)
Subject: Re: Normals in Pov
Date: 18 Jul 2000 22:22:40
Message: <chrishuff-0591C5.21231018072000@news.povray.org>
In article <3974E13A.49899E8C@erols.com>, John VanSickle
<van### [at] erolscom> wrote:
> This is what I tested; the normal does indeed need to be flipped to
> achieve this effect.  I'm fairly sure this was done in a recent
> version of POV-Ray; I distinctly remember having to reverse the order
> of some defined points in order to get the normals pointed the right
> way.
I think the bug fix was added in 3.1b along with some double-illuminate
stuff:
"Fixed average normal bug and other normal flipping problems"
(revision.doc)
Date: 19 Jul 2000 04:50:24
Message: <39756bd0@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: I think the bug fix was added in 3.1b along with some double-illuminate
: stuff:
: "Fixed average normal bug and other normal flipping problems"
  But flipping the normal vector of a (non-smooth) triangle is NOT a bug! It's
the right behaviour.
  Think about a plane { y, 0 }. If you put a light source at y*10 it will
illuminate the top of the plane and the bottom will be shadowed. If you put
the light source at y*-10, it will be the other way around.
  Now, this same behavior has to happen with regular triangles as well. If
the light source is at one side of the triangle, that side has to be
illuminated and the other shadowed. It doesn't matter which side.
  To achieve this, the normal vector has to be flipped to point to the side
where the light source is. If the normal vector were pointing to the wrong
side, the side of the triangle which is facing the light source would be
shadowed, which is the wrong result.
Date: 19 Jul 2000 08:23:39
Message: <39759DCA.E0B64DE7@erols.com>
> : stuff:
> bug! It's the right behaviour.
> will illuminate the top of the plane and the bottom will be shadowed.
> If you put the light source at y*-10, it will be the other way around.
I was speaking of the calculations for normal patterns; the behavior
does seem to have changed since the 3.0 days.
John
Date: 19 Jul 2000 10:42:00
Message: <chrishuff-AB58C8.09423219072000@news.povray.org>
In article <39756bd0@news.povray.org>, Warp <war### [at] tagpovrayorg>
> : stuff:
Umm, that's why it was added. Flipping the normal is the bug fix I was
talking about. Before, it wasn't done, and sometimes caused problems. :-)
Date: 20 Jul 2000 05:56:42
Message: <3976ccd9@news.povray.org>
: Umm, that's why it was added. Flipping the normal is the bug fix I was
: talking about. Before, it wasn't done, and sometimes caused problems. :-)
  Oh, sorry. I got confused.
Date: 21 Jul 2000 16:20:48
Message: <chrishuff-A46E70.15212321072000@news.povray.org>
In article <39759DCA.E0B64DE7@erols.com>, John VanSickle
There have been changes...and wasn't there a limitation on what patterns
could be used as normals in the 3.0.x versions? I think some of those
changes had to do with allowing any pattern to be used.
Anyway, there will be even more changes...check out MegaPOV for a
"preview" of what 3.5 should be like. Most of the changes have to do
with making the normal scale more reasonably, they now act much more
like actual surface deformations would.
