POV-Ray : Newsgroups : povray.newusers : Bright Spot aka Fire Fly Server Time
13 Jul 2026 07:27:42 EDT (-0400)
  Bright Spot aka Fire Fly (Message 1 to 7 of 7)
Subject: Bright Spot aka Fire Fly
Date: 1 Jul 2000 16:14:59
Message: <395e5143$1@news.povray.org>
I'm trying to make a bright yellow glowing spot.
I've tried a sphere to and emitting yellow media, and a point light in
a sphere.
Thanks in advance for any advice.
I got it work with a halo, but alas I can't get it to work with media
Heather
hjpinnix@mindspring
Subject: Re: Bright Spot aka Fire Fly
Date: 1 Jul 2000 16:53:24
Message: <tamsls8enlpmpfoimurarfdkmktofhp1pk@4ax.com>
On Sat, 1 Jul 2000 16:17:16 -0400, "Heather Pinnix"
>a sphere.
Emitting media should work. Was your container object hollow? Try
something like
sphere
{ 0, 1
  pigment { rgbf 1 }
  interior
  { media { emission Yellow absorption Blue density { spherical } }
You can also try to do it with a lens flare using Chris or Nathan's
include files.
Peter Popov ICQ : 15002700
Date: 1 Jul 2000 17:01:06
Message: <chrishuff-65E451.16011201072000@news.povray.org>
In article <395e5143$1@news.povray.org>, "Heather Pinnix"
> a sphere.
I do it in one of two ways, depending on what I need. Media is slower,
but much more versatile, and if you use MegaPOV and sampling method 3,
the speed isn't usually a problem. The light-sphere-highlight method is
normally much faster, and gives light to surrounding objects, but can't
do some of the things media can do, and could really slow things down if
you have a lot of "spots".
You might also want to look at one of the lens flare includes:
NKFlare: http://nathan.kopp.com/nkflare.htm
Chris Colfax's Lens Effects: http://www.geocities.com/ccolefax/
    location <0, 3.5,-10>
    angle 45
    look_at <0, 0, 0>
box {<-100, 0,-100>, < 100, 0, 100>
    texture {pigment {checker color Black, color White}}
//the media method
//make sure you use the "hollow" keyword. And don't
//forget that media is scale-dependant, a greater thickness
//of media will be brighter.
sphere {< 0, 0, 0>, 1
    texture {pigment {color White filter 1}}
    hollow
    interior {
        media {
            emission color rgb < 1, 1, 0.2>
            samples 15
            density {spherical
                color_map {
                    [0 color Black]
                    [1 color White]
    translate < 2, 1.2, 0>
//light-sphere-highlight method
//The glow is actually the highlight from the light source
//on the sphere.
union {
            finish {
                specular 1
    light_source {<0,0,0> color rgb < 1, 1, 0.2>}
    translate <-2, 1.2, 0>
Date: 1 Jul 2000 17:31:43
Message: <395e633f@news.povray.org>
Taking all the fun out of do-it-yourself, there's this:
#declare GS=
sphere {0,1 hollow
        pigment {rgbf 1}
 interior {
  media {intervals 12 samples 3,3
        emission <.67,.75,.33> absorption <.33,.25,.67>
         scattering {4,<.67,.75,.33>} // type 1 is softer, 2-4 tighter and
intense
          density {spherical
                   density_map {
                    [0 rgb 0]
                    [.33 rgb .75] // vary index to change sharpness/softness
                    [1 rgb 1]
                    }ramp_wave}}
#declare GlowSpot=
light_source {0,<.67,.75,.33>
  looks_like {GS}
        fade_distance 1 fade_power 2
GlowSpot
camera {location -5*z
        look_at 0
plane {y,-1.01 pigment {rgb 1}}
Date: 3 Jul 2000 18:53:04
Message: <3961187A.C5ADC831@spiritone.com>
Yet another way to do this:
#declare light_object =
   sphere { 0,1
            pigment {  rgbf <1,1,1,1> }
            finish { specular 5 metallic} }
 light_source { 0*x color rgb <1,0.75,0> looks_like { light_object } }
From my Cyclopedia entry on the "looks_like" statement.
Josh English
> a sphere.
> Heather
> hjpinnix@mindspring
Josh English
eng### [at] spiritonecom
Date: 3 Jul 2000 19:13:14
Message: <chrishuff-AB4E4D.18132403072000@news.povray.org>
In article <3961187A.C5ADC831@spiritone.com>, Josh English
And another:(untested, but it should work)
#macro LightningBug(CameraPos, BugPos, Radius, Col)
    disk {BugPos, CameraPos-BugPos, Radius
            pigment {spherical
                color_map {
                    [0 color rgbf < 1, 1, 1, 1>]
                    [1 color Col]
                translate BugPos
            finish {ambient 1}
Date: 5 Jul 2000 22:10:48
Message: <3963E869.1A4BD53C@global2000.net>
Try using this.
interior
media { emission <0.75,1,0> absorption <0.25,0,1>
density { spherical } } }
It looks more green.
Brendan Ryan
> >a sphere.
> something like
> sphere
> { 0, 1
>   pigment { rgbf 1 }
>   interior
> include files.
> Personal e-mail : pet### [at] usanet
> TAG      e-mail : pet### [at] tagpovrayorg
