POV-Ray : Newsgroups : povray.newusers : How to keeping texture after CSG? Server Time
11 Apr 2026 10:59:19 EDT (-0400)
  How to keeping texture after CSG? (Message 1 to 5 of 5)
Subject: How to keeping texture after CSG?
Date: 24 Jun 2000 15:55:55
Message: <3955124b$1@news.povray.org>
I want to model a shield for my guard. I want to make it out of wood-planks
and intersect it in shape. There is the union of the wood-planks (with
individually translated textures) which looses its texture while differenced
or intersected with a sphere. As I read, this is totally normal - but
annoying.
I can't apply the texture after the csg-operation, because it then seems to
be made out of one piece of wood.
Can I keep the "planked" wood-texture in my csg or do I have to mimmic this
with a texture_map (or something like this)?
Thanks,
Marc-Hendrik
Subject: Re: How to keeping texture after CSG?
Date: 24 Jun 2000 16:14:26
Message: <chrishuff-C13BCA.15185324062000@news.povray.org>
In article <3955124b$1@news.povray.org>, "Marc-Hendrik Bremer"
> wood-planks and intersect it in shape. There is the union of the
> wood-planks (with individually translated textures) which looses its
> texture while differenced or intersected with a sphere. As I read,
> this is totally normal - but annoying.
Just change the order of things a bit...intersect each plank
individually, texture the resulting intersection objects, and place the
intersections in the union. In other words, use a union of intersections
instead of an intersection of a union.
To make things easier, #declare the sphere and use object {sphereName}.
That way, you don't have to redo every copy of the sphere to make a
small adjustment. This is also more efficient in some cases, since you
can choose to only do an intersection/difference on the planks which
will be affected by it.
Instead of:
intersection {
    union {
        object {Plank texture {...} translate...}
    sphere {...}
Do it like this:
#declare MySphere =
sphere {...}
union {
    intersection {
        object {Plank}
        object {MySphere}
        texture {...}
        translate ...
    intersection {
        object {Plank}
        object {MySphere}
        texture {...}
        translate ...
    intersection {
        object {Plank}
        object {MySphere}
        texture {...}
        translate ...
Date: 24 Jun 2000 16:14:33
Message: <395516a9$1@news.povray.org>
In article <3955124b$1@news.povray.org> , "Marc-Hendrik Bremer"
> annoying.
Don't use a union, just intersect each part with a sphere.
     Thorsten
Date: 24 Jun 2000 16:56:24
Message: <39552078@news.povray.org>
thank you all!
Of course you are both absolute right! That's what you get, when you reuse
code from another scene - you can't see the obvious solution!
Marc-Hendrik
Date: 27 Jun 2000 04:25:53
Message: <39586510@news.povray.org>
The easiest solution is to use the cutaway texturing feature of megapov.
I think it does exactly what you want.
