POV-Ray : Newsgroups : povray.newusers : Transparent Server Time
24 Dec 2025 22:49:15 EST (-0500)
  Transparent (Message 1 to 7 of 7)
Subject: Transparent
Date: 21 Jun 2000 14:23:17
Message: <3951070C.16F829ED@mbfys.lu.se>
how do you set the level of transparency of an object
Subject: Re: Transparent
Date: 21 Jun 2000 16:38:17
Message: <395127b9$1@news.povray.org>
Well, I might understand your question wrong, but look it up under "Using
Transparent Pigments and Layered Textures" in the Pov-Ray Documentation (it
is in the tutorial). Basically use rgbt <redcol,greencol,bluecol, transmit>
or rgbf <redcol,greencol,bluecol, filter> in the pigment{}-statement, with
"transmit" or "filter" set to something greater than 0. A value of 1 means
the object is fully transparent,
HTH,
Marc-Hendrik
Michel Fodje schrieb in Nachricht <3951070C.16F829ED@mbfys.lu.se>...
Date: 21 Jun 2000 17:24:22
Message: <slrn8l2d9d.b2s.ron.parker@linux.parkerr.fwi.com>
On Wed, 21 Jun 2000 20:18:52 +0200, Michel Fodje wrote:
>aG93IGRvIHlvdSBzZXQgdGhlIGxldmVsIG9mIHRyYW5zcGFyZW5jeSBvZiBhbiBvYmplY3QN
>Cg0K
Please fix your newsreader so it doesn't encode iso-8859-1 as base64.
Thanks.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 22 Jun 2000 08:04:30
Message: <395200ce@news.povray.org>
Perhaps you should have also said what's the difference between transmit
and filter.
Date: 22 Jun 2000 09:01:12
Message: <39520e18$1@news.povray.org>
Perhaps I should have done, but I could not imagine how to say it more
accurate as the mentioned part of the docs do - filter filters the light,
while transmittance let the light pass unchanged, doesn't it?
Marc-Hendrik
Warp schrieb in Nachricht <395200ce@news.povray.org>...
>and filter.
Date: 22 Jun 2000 10:59:13
Message: <395229c0@news.povray.org>
Marc-Hendrik Bremer <Mar### [at] t-onlinede> wrote:
: Perhaps I should have done, but I could not imagine how to say it more
: accurate as the mentioned part of the docs do - filter filters the light,
: while transmittance let the light pass unchanged, doesn't it?
  Not exactly. The light passes unchanged only if transmit is 1. If it's
less than 1 then it changes the light.
Date: 22 Jun 2000 15:17:09
Message: <39526635$1@news.povray.org>
Well, I knew why I didn't say what the difference of the two are in my first
post:-)
But okay, with Transmittance the intensity of the light passing through is
changed according to the chosen transmit-value but not it's colour.
Warp schrieb in Nachricht <395229c0@news.povray.org>...
