POV-Ray : Newsgroups : povray.newusers : filtering of tga image map Server Time
19 Jun 2026 09:36:50 EDT (-0400)
  filtering of tga image map (Message 1 to 8 of 8)
Subject: filtering of tga image map
Date: 12 Jun 2000 16:57:00
Message: <3945A375.8A85C7D3@home.nl>
I've an image map like:
image_map { tga "foto.tga" filter all 1 }
But the photo is still there. When I specify filter 1, 1, I get the
error: Keyword 'filter' cannot be used non color-mapped image.
What's the problem?
Remco Poelstra
Subject: Re: filtering of tga image map
Date: 12 Jun 2000 17:10:34
Message: <394551ca@news.povray.org>
A non-256 color (8bit to be more precise) image can't use the index since
there isn't any.
filter all can filter the entire thing but then it's only being "filtered" so
any non white parts will still be visible.
You could use transmit all,1 instead but of course it's going to be completely
gone then too.  So partial amounts of transmit would be needed to still see
the image.
"Remco Poelstra" <rjp### [at] homenl> wrote in message
news:3945A375.8A85C7D3@home.nl...
| What's the problem?
Date: 12 Jun 2000 17:21:28
Message: <3945A931.FE0D9A41@home.nl>
> there isn't any.
> the image.
> Bob
Thanks, it works now!
Remco Poelstra
P.S. Is there a way to let povray ouput 256 color images?
Date: 12 Jun 2000 17:38:44
Message: <39455864@news.povray.org>
news:3945A931.FE0D9A41@home.nl...
No, POV wasn't meant to output such low color depth.  Although it can make as
low as 15 bit color PNG images using +FN5 (plus f n five).
Date: 12 Jun 2000 22:46:35
Message: <3945A042.5CC81E66@erols.com>
No.  But some versions come with a TGA-to-GIF utility.
John
ICQ: 46085459
Date: 15 Jun 2000 01:18:19
Message: <3948671b@news.povray.org>
"Bob Hughes" <per### [at] aolcom?subject=PoV-News:> wrote in message
news:394551ca@news.povray.org...
| there isn't any.
so
completely
| the image.
Ack!  How wrong I can be sometimes.  Forget I ever said the above about filter
all,1.
For one thing the comma causes an error, for another it never will filter or
transmit all anyhow.
I should have checked first before speaking.  The 'filter all 1' will parse
and render but won't actually do any filtering, as you had seen already.
I wasn't too clear to begin with either I think.  24 bit and other such
non-256 color images cannot be "indexed" into POV-Ray since the whole thing is
based on the idea of using from 2 to 256 entries.
So I hope that clarifies it for the new user better.  Makes more sense to read
the documentation than it does to listen to me most of the time.
| | What's the problem?
Date: 15 Jun 2000 01:39:39
Message: <39486B70.D5E0585B@pacbell.net>
Bob Hughes wrote:
> Ack!
<snip>
> Makes more sense to read the documentation than it does to listen
Sometimes it is just better to rely on the VFAQ to answer these types
of questions :)
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#imagemapfiltering
Date: 15 Jun 2000 14:02:15
Message: <39496F03.985F0D91@home.nl>
Ken wrote:
> Bob Hughes wrote:
> > Ack!
> <snip>
> of questions :)
Or perhaps I should have searched better.
Remco
