POV-Ray : Newsgroups : povray.newusers : Constructive Solid Geometry Server Time
19 Jun 2026 11:29:40 EDT (-0400)
  Constructive Solid Geometry (Message 1 to 10 of 11)
Subject: Constructive Solid Geometry
Date: 20 Mar 2000 18:48:08
Message: <38D6B89B.B5FD14D5@fcmail.com>
is it possible to subtract two shapes in a single difference statement?
as in this:
difference {
  box1       //the box that is subtracted from
  box2       //box1 has this shape subtracted from it
  box3       //does box3 have this shape subtracted from it as well?
}//end difference statement
and can anyone point me to a tutorial on csg?
Many thanks for any help,
CMcCabe
Subject: Re: Constructive Solid Geometry
Date: 20 Mar 2000 19:06:58
Message: <38D6BD83.A1A21A46@pacbell.net>
> as in this:
> difference {
> CMcCabe
It is easist to think of this way. Box 1 is the only object acted upon
in a csg operation (the first object in a csg operation). In the above
example box 1 will be acted upon by box 2 and box 3 but box 2 will not
be acted upon by box 3.
It is possible to nest csg operations -
difference {
             union {
                    box1
                    box2
             box3
In the above box 1 and box 2 are unioned together and then differenced
by box 3 so that box 1 and box 2 are both acted upon by box 3.
intersection {
               merge {
                        box 1
                        box 2
               box 3
In the above box 1 is merged with box 2, and then box 1 and box 2,
are both intersected by box 3. You can use any combination and depth
of csg nesting to acheive the desired shape you are looking for.
POV-Ray tutorials can be found by following this link
http://www.povray.org/links/3D_Tutorials/POV-Ray_Tutorials/
Date: 21 Mar 2000 17:20:19
Message: <38D7F57D.76260680@fcmail.com>
i found out what i did wrong and now have another question
in using a merge or difference statement, why is it that objects just
dissappear if they are not touching?
as for tutorials...  after doing a text search for 'geometry' or 'csg' in the
page, i couldn't find what i was looking for
Date: 21 Mar 2000 18:28:38
Message: <38D8060D.7D4178F6@pacbell.net>
It would be hard to say unless you provided me with a specific example
to look at. Needless to say a CSG operation (except a union) requires
that the objects in the CSG must be touching for the operation to work
properly. In your original example the only object that would ever be
visible in the scene would be box 1. Box 2 and box 3 are only reference
shapes for the operation and would not be visible regardless if they
touched box 1 or not.
Try this page; chapter 8 - http://jan.ucc.nau.edu/~dld6/pov_lessons/index.html
Date: 22 Mar 2000 16:53:56
Message: <slrn8dhqq0.4tp.sjlen@zero-pps.localdomain>
The POV documentation describes CSG very well along with examples.
When I first got POV, I printed the whole manual out and used to take
various sections to work with me so that I could read them on the bus.
  3:41pm  up 3 days, 12:16,  6 users,  load average: 1.81, 1.50, 1.25
Date: 22 Mar 2000 17:49:24
Message: <38D94E50.56F2D68B@pacbell.net>
Gee Steve, was that a disguised RTFM relpy I just detected ? :)
Date: 23 Mar 2000 02:26:05
Message: <38d9c70d@news.povray.org>
"Steve" <sjl### [at] ndirectcouk> wrote in message
news:slr### [at] zero-ppslocaldomain...
Any simple way to reformat the manual so that it will print compactly--in
other words, without reams of white space/scratch paper between
sub-sections?
s. (who reads TFM on his smoke breaks, but keeps a quad notebook for ideas)
Date: 23 Mar 2000 04:43:23
Message: <38D9E780.19D60849@pacbell.net>
> sub-sections?
Besides the Windows .hlp format there are 3 other versions of the docs
available at the link below - .pdf, .doc, and html. Choose your favorite.
http://www.povray.org/ftp/pub/povray/Official/Docs/
Date: 23 Mar 2000 06:22:21
Message: <slrn8diq1q.5ks.sjlen@zero-pps.localdomain>
Yes: The only thing I forgot was the links to the pov docs in all their
different forms.
I've been using the product for about two years now and still use my
text based version of the Official Pov docs for almost every single
pov project I work on, I've even got a little script that opens it
up for me in it's own Xterminal window with my prefered colours,
I've named the script 'emanuel'.
 12:35am  up 3 days, 21:10,  5 users,  load average: 1.18, 1.28, 1.21
Date: 23 Mar 2000 09:19:18
Message: <38da27e6@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38D9E780.19D60849@pacbell.net...
Thanks, Ken--I should have known.....
I've been getting warnings about a damaged help file, lately, and need to
fix it anyway.
May the road rise to you, and your PPS be faster than your typing speed.
s.
