POV-Ray : Newsgroups : povray.newusers : Dumb question that must be asked. Server Time
19 Jun 2026 11:29:54 EDT (-0400)
  Dumb question that must be asked. (Message 1 to 3 of 3)
Subject: Dumb question that must be asked.
Date: 11 Mar 2000 16:07:28
Message: <38CAB24D.4989EC8@aol.com>
I post images( who doesn't) on the image board, put to those who look at
them, say its to dark. They posted a base line for monitor settings, and
reset the settings as told to, put this problem still happens. What can
I do in Mega-POV to brighten the image?
Subject: Re: Dumb question that must be asked.
Date: 11 Mar 2000 16:19:16
Message: <38CAB807.F72DC823@pacbell.net>
At the top of your scene file try inserting the following line
global_settings { assumed_gamma 2.0 }
The smaller the number you use the brighter your scene will be.
Make sure that you are not using your monitor with the brightness
and contrast controls maxed out. If the black areas of the scene
look a little gray your monitor brightness/contrast is set too
high !!!
  The other alternative is to manualy adjust the brightness of your
scene objects by adjusting their ambient and diffuse values in the
finish statement.
example - finish { ambient .3 diffuse .5 }
or
Use more light sources or place them better ?
Date: 11 Mar 2000 18:52:58
Message: <chrishuff_99-D207E1.18544711032000@news.povray.org>
In article <38CAB807.F72DC823@pacbell.net>, lin### [at] povrayorg
> finish statement.
It should be mentioned that increasing ambient will cause loss of depth
in your objects. It basically sets the minimum level of light that will
be used in the color calculations. Raising it will make your shadows
brighter, going more toward a flat color over everything, with no
shading.
Chris Huff
e-mail: chr### [at] yahoocom
