Hi!
I'm totally new user to POV-Ray and I use POV-Ray for Windows v3.1. I ran in
first problem: is it possible to choose output file format anywhere in
POV-Ray window or do I have to use command line switches? I'd like render
pictures by pressing 'Render' button rather than using command line
switches.
Paulus
paulus wrote:
> Hi!
> switches.
> Paulus
You can specify the image format inside of an ini file using a switch so that
you don't have to specify it each time on the command line. For example I use
the switch for .tga output as my default. To do this I went to the tools
menu and selected the option to "edit master povray.ini" and added the following
line to the end of the .ini file - Output_File_Type = t . Save the file,
close out of POV-Ray, then restart before the option will take effect.
For other file formats look up the proper switch to use in the docs.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Thanks a lot :)
>paulus wrote:
>> Hi!
in
>> switches.
>> Paulus
that
use
following
>http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
