POV-Ray : Newsgroups : povray.newusers : Merge vs. Union Server Time
14 Jun 2026 23:45:33 EDT (-0400)
  Merge vs. Union (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Merge vs. Union
Date: 20 Sep 1999 01:08:54
Message: <37e5c166@news.povray.org>
Haha!  This is kinda what I was looking for in the first place!
It sums everything up pretty well ;)
-Ian
>   I like to think of CSG operations as to how they perform physically in
> an operation. My idea of more better analogies would be:
> union        = gluing
> intersection = cutting
> difference   = scooping
> merge        = melting and gluing
> clipping     = cutting and hollowing
> inverse      = inside outing
> There ! That should give you something to cry in despair over for a while
> Ken Tyler
> See my 1000+ Povray and 3D Rendering and Raytracing Links at:
> http://home.pacbell.net/tylereng/index.html
Date: 20 Sep 1999 06:32:51
Message: <37e60d53@news.povray.org>
Ron Parker <par### [at] fwicom> wrote:
: It's also
: possible that POV automatically ignores objects that are entirely
: further away than the closest intersection so far.  If it doesn't,
: it should.
  How can it know if the object is further or not without testing the
ray-object intersection?
Date: 20 Sep 1999 06:40:03
Message: <37e60f03@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: intersection = cutting
: difference   = scooping
  I have always thought about the difference as cutting parts out from the
main object.
: clipping     = cutting and hollowing
  Is clipping considered CSG? Note that the 'S' stands for 'solid' :)
  I think that it would also be useful if you explained the difference
between intersection and clipping and when it's better to use clipping
instead of intersection.
Date: 20 Sep 1999 09:10:26
Message: <37e63242@news.povray.org>
>: It's also
>: it should.
By taking the dot product of each of the six bounding box coordinates
with the ray direction.  If they're all further away, then the object
must be.
Date: 20 Sep 1999 09:42:35
Message: <37E63949.2EB6142F@pacbell.net>
> main object.
In english the word "scooping" implies that but perhaps not as definitavely as
you have stated it.
You might be right here.
Intersections will slice or cut an object and then apply a face where the
slice has been made.
Clipping slices an object but will not leave a face where the slice has
occured. Instead the object that has been sliced will now appear to be
hollowed out since all solid objects in POV-Ray are not truly solid.
Ken Tyler
Date: 20 Sep 1999 11:15:00
Message: <37e64f74@news.povray.org>
: By taking the dot product of each of the six bounding box coordinates
: with the ray direction.  If they're all further away, then the object
: must be.
  You forget that the bounding box is not necesarily around the object...
nor it is a box... :)
Date: 20 Sep 1999 11:18:20
Message: <37e6503c@news.povray.org>
clipped_by should be used instead of difference when the new surface is
not seen (for example, if you clip a torus and attach two cylinders to the
ends to form a bended tube, the clipped surfaces are inside the tube and thus
are not seen).
  Why it should be used? Because it's faster to render.
Date: 20 Sep 1999 11:33:45
Message: <slrn7uckup.v8.parkerr@ron.gwmicro.com>
>: must be.
You forget that if it's not around the object, it shouldn't matter to the
ray-intersection routine (obviously in practice it works in such a way that
vampire objects are possible, but that's a side-effect that could easily
disappear with better optimization.)  And rest assured that finite objects
have bounding boxes whether or not such boxes are specified in the script;
that's how the min_extent and max_extent keywords in the superpatch work.
Date: 20 Sep 1999 22:39:25
Message: <8u7mN7YBUwm+FzRn=xEYg=hGmGWG@4ax.com>
  Ken, I've always thought of intersection as an area of common overlap
among objects.
Alan ---------------------------------------------------------------
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 20 Sep 1999 22:48:44
Message: <37e6f20c@news.povray.org>
Same here...
