POV-Ray : Newsgroups : povray.newusers : Image map on paper Server Time
2 Jan 2026 01:16:29 EST (-0500)
  Image map on paper (Message 11 to 13 of 13)
Subject: Re: Image map on paper
Date: 13 Sep 1999 16:47:57
Message: <37DD634D.2433C746@compuserve.com>
Yes, I had to work around that for my reflectivity patch. An annoying
little bit of code...
Date: 22 Oct 1999 15:49:09
Message: <3810DB3D.5463A702@janics.com>
Saadat Saeed wrote:
> I have created a paper on PovRay and have mapped a scanned newspaper onto
> it. Now, the scanned newpaper appears on both sides on the newspaper.
> Oneside is what I want and the other side is in reverse. I'd like to keep
> the other side blank AND/OR and different image map on the other side. Can
> anyone guide me to the two different possibilities?
> BR/Saadat Saeed
  I just downloaded the g version for MS-dos, so I don't know if this will
work in all versions.
#declare Box=box{<0,0,1>,<4,4,0>
 texture {pigment{image_map { tga "Image.tga"
 map_type 0 interpolate 2} }
 scale<2,4,1> }}
#declare Box2=box{<0,0,0>,<2,10,.1>
 texture {pigment{image_map { tga "Image2.tga"
 scale<2,4,1> }}
// white back side of paper
#declare Pg=intersection{
 object{Box}
 box{<0,0,0>,<2,10,.1> pigment{White}}
// Image2 on back side of paper
 object{Box}
 object{Box2}
You can also use the Height_field this way too.
Late but, Hope this helps.
Download 'us-ascii' (2 KB)
Date: 22 Oct 1999 18:47:24
Message: <3810E978.927D803@spiritone.com>
There is also a neat solution at
http://www.spiritone.com/~english/cyclopedia/index.html#coins0
Leroy Whetstone wrote:
>> onto
>> newspaper.
>> keep
>> side. Can
>> BR/Saadat Saeed
> will work in all versions.
>  scale<2,4,1> }}
>  scale<2,4,1> }}
>  object{Box}
>  object{Box}
>  object{Box2}
Josh English
eng### [at] spiritonecom
icq 1946299
"Stress is when you wake up screaming and realize you haven't fallen
asleep yet."
