POV-Ray : Newsgroups : povray.newusers : Sometimes Image map is more appropriate then texture? Server Time
22 Nov 2025 10:31:25 EST (-0500)
  Sometimes Image map is more appropriate then texture? (Message 1 to 5 of 5)
Subject: Sometimes Image map is more appropriate then texture?
Date: 30 Jul 1999 10:27:38
Message: <37a1b65a@news.povray.org>
I'm working on the hull for a boat.  I don't think "carving" the hull from a
texture is appropriate, in this case, as the boat would be made of planks of
wood or plates of metal.  This would probably best be done by wrapping an
image map and bump map on each side of the hull.  I don't want to model
individual planks.
Since I'm new at this, I thought I'd check with you knowledgable folks and
give you a chance to set me straight.
-s
Subject: Re: Sometimes Image map is more appropriate then texture?
Date: 30 Jul 1999 10:39:01
Message: <37A1B863.B71F5DF5@pacbell.net>
> individual planks.
> -s
  You open yourself to attacks by purists and wild fanatics alike. On the one
hand making the individual planks adds an extra step of realism that is hard
to mimic with textural methods. On the other textural methods are often faster
and easier to apply and can give satisfactory results if done properly. I
would say evaluate how close to the camera is the ship/boat going to be ant
decide from there. Up close you may wish to go with the physical modelling
process. If it is to be seen from a distance such as out on a lake a ways
then you can probably get away with the textural method. Think about which
method is going to give you the most satisfaction when it is done and let
your own conscience be your guide.
  See my links collection in the announcement group for a massive list of
of online texture resources if you decide to go with image maps. There are
some excellent wood plank textures at the sites listed in that collection.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 30 Jul 1999 11:36:45
Message: <37a1c68d@news.povray.org>
Great.  You gave me an intelligent, balanced, non-furious response.  Well,
that's the thing...I may end up doing both, depending on how things go.
It sure is going to be painful modelling each plate of the metal hull, but
for up-close shots, that may be the best way.
Thanks for the texture links.  I'm looking for a good Jules Vernes 20,000
leagues nautilus hull metal plating texture.
Ken wrote in message <37A1B863.B71F5DF5@pacbell.net>...
from a
of
>> individual planks.
and
>> -s
one
hard
faster
>Ken Tyler
Date: 30 Jul 1999 17:44:15
Message: <37a2da01.7592394@204.213.191.228>
On Fri, 30 Jul 1999 10:38:02 -0500, "Skelter"
Doesn't he always?
Peter Popov
ICQ: 15002700
Date: 30 Jul 1999 18:50:49
Message: <37A21C64.EDA7A5E4@ndirect.co.uk>
Skelter
I don't know if you've investigated macros and while loops yet,
they can take a lot of the drugery out of making multiple similar
objects.
Eg:
#declare OnePlank =
difference{
               cylinder{<0,0,0>, <0,0.25,0>,1
                           scale <1.25,1,1>
                           texture{some sorta wood/metal}
#declare BoatHull =
union{
         #local CountScale = 0.05;
         #local PlankScale = 0.5;
         #local PlankPlace = 0.25;
         #while(PlankScale<2)
             object{
                       OnePlank
                       scale<PlankScale,1,PlankScale>
                       translate <0,PlankPlace,0>
             #local PlankPlace = PlankPlace+0.25;
             #local PlankScale=PlankScale+CountScale;
object{BoatHull}
Something like that, hope it helps.
> from a
> of
> >> individual planks.
> and
> >> -s
> one
> hard
> faster
> >Ken Tyler
Steve
%HAV-A-NICEDAY Error reading file mailto:sjl### [at] ndirectcouk
