POV-Ray : Newsgroups : povray.newusers : skipping an object temporarily Server Time
22 Mar 2026 20:55:14 EDT (-0400)
  skipping an object temporarily (Message 1 to 6 of 6)
Subject: skipping an object temporarily
Date: 25 Aug 1999 15:17:02
Message: <37C4416F.917EDA0A@accn.org>
Is there an easy way to skip rendering an object? Like using a GOTO to
skip over it? I don't want to have to delete the whole object or comment
out 20 lines to comment it out.
Thanks.
Subject: Re: skipping an object temporarily
Date: 25 Aug 1999 16:03:56
Message: <37C44BF6.3ABCC933@pacbell.net>
> Thanks.
The easiest way is to simply declare the object as something.
For example:
#declare Thing =
union{
sphere{<1,0,0>,1}
sphere{<0,1,0>,1}
sphere{<0,0,1>,1}
sphere{<1,1,0>,1}
sphere{<0,1,1>,1}
//object{Thing}
As you can see you need only comment out one line this way. This is of course
a simplified version and you would normaly have finishes and pigments for the
objects.
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 25 Aug 1999 16:25:15
Message: <37C4516A.3CB402BA@accn.org>
Yes. And another way is:
	#if (false)
	plane {...
and another way:
	/* plane
Date: 25 Aug 1999 22:30:16
Message: <37c7a24a.676259011@news.povray.org>
On Wed, 25 Aug 1999 15:18:07 -0400, Chuck Roberts <rob### [at] accnorg> wrote:
  Here's a portion of scene code from a recent trace I did. It isn't my
original idea to call it render control. An artist shared his source with me
and I took to using this method for quick test renders. My apologies to the
artist as I have forgotten his name.
/* Render Control */
#declare Photons_on                =   1;
#declare phd                       =0.75; // 0.5
#declare Area_light_on             =   1;
#declare Refl_Refr_on              =   1;
#declare Focal_blur_on             =   1;
#declare Focal_blur_high_quality   =   1;
#declare Plastic_box_on            =   1;
#declare Innards_on                =   1;
#declare Test_ball_on              =   0;
#if (Test_ball_on)
sphere {<-4,-5,4>,1
   pigment {color rgb 1.5}
   finish {ambient .2 diffuse .6 specular .3 roughness .005}
#end // (Test_ball_on)
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 27 Aug 1999 16:18:15
Message: <37c6f287@news.povray.org>
In article <37C4416F.917EDA0A@accn.org> , Chuck Roberts <rob### [at] accnorg>
Aren't multiline /* ... */ comments simple enought? You only need to alter
two lines :-)
    Thorsten
Date: 27 Aug 1999 18:30:53
Message: <37C71155.D048A102@pacbell.net>
> two lines :-)
>     Thorsten
I would have given up long ago without them !
Ken Tyler
