Thanks everyone!
I finally have had time to work through PhotoModeler - LOVE IT!
For a beginner in 3-D it is easy to use but fairly powerful....and free?!?
Most freeware demos that I have downloaded is so limited that it is useless -
most
of the time, I don't even want to spend the time to learn if I would want to
purchase.
I am also slowly working through learning POV because it appears to be so
powerful!
Thanks for the leads and links!
Clint
Cli### [at] postoffice2 bellatlantic net wrote:
> Thanks Ken and Bob! I downloaded the Naboo model and PhotoModeler. I am
> anxious to try them both! Two more questions, if I might:
> 1. What program would you suggest for stretching, modifying, and "morphing"
> the model into a variation?
> 2. Once finished is there a program that would permit cross-sections (or
> something similar) to be printed to allow me to physically build the model.
> Thanks again,
> Clint
> Ken wrote:
> > Bob Hughes wrote:
> > > And for the more "on your own" method as was asked for:
> > > http://www.eossystems.com/Lite/
> > > Check that web page out, there's a free demo of a program to make photos
> > > (drawings possible too) into a 3D model (DXF). You supply a few pictures
> > > of a object from various perspectives (viewing angles) and the manual
> > > creation of the model vertexes, lines, and surfaces is also up to you.
> > > Well, just take a look and try it out, you'll see. The setup really
> > > needs a digital camera, not sure if you can get around that. Seems the
> > > setup allows for various ways to setup though. Been a while since I
> > > tried it.
> > > Mike Hough brought it up at AOL once and that's how I know of it and I
> > > later saw it there in AOLs software libraries. It seems quite a good
> > > program, just not super simple.
> > Ok Bob. He can use the model I provided a link for as an example of
> > physical demensions and digitaly photograph it using Pov from any angle
> > needed :)
> > Ken Tyler
> > mailto://tylereng@pacbell.net
> > http://home.pacbell.net/tylereng/links.htm
