POV-Ray : Newsgroups : povray.newusers : for once a question on why something does what it does insted of how to do something Server Time
13 Jul 2026 12:28:23 EDT (-0400)
  for once a question on why something does what it does insted of how to do something (Message 1 to 4 of 4)
Subject: for once a question on why something does what it does insted of how to do something
Date: 11 Jul 1999 20:24:02
Message: <37893467.12BA2241@x-press.net>
first off I'm a newbie pov user so if I state anything bare with me
(only using pov around 2 weeks)
anywho I was messing around with the media keyword trying to get some
kind of volumetric lighting in the scene I was working in, and since the
pov-ray docs are pretty lacking in there explination of the media
keyword I opened up one of the sameple files and copy and pasted the
code
now what I was trying to do was get a solid blue beam of light, but
insted what I got looks more like a particle stream. which is really
cool and I'm glad I got it, but I'd like to know why it did what I
did...I'd like to be able to reproduce that effect and actully
understand the media keyword since it's kinda complicated
anyway here is the code I used for the light (image is available here
http://www.angelfire.com/on2/lycsorp/images/silence640x480.jpg )
//define particulate media
media {
  intervals 20
  scattering {3, rgb .02}
  samples 1, 10
  confidence 0.9999
  variance 1/1000
  ratio 0.9
light_source {
<0,10,initial_depth>
color rgb <1,1,2>*100
cylinder
point_at <0,0,initial_depth>
radius 10
falloff 10
media_attenuation on
so if someone wants to explain why the light beam looks like a particle
srteam I would be most greateful,
thanks!!
P.S this is really for the pov team. I've been using bryce (*gags*)
before to do my rednering and I just couldn't handle the freaking klunky
interface so I tried out pov and boy am I impressed!!! for free it does
more then a lot of programs I've seen and since it's really just a
programing language it's more powerful. great job and keep up the good
work!!
Subject: really bad typos
Date: 11 Jul 1999 20:32:52
Message: <37893679.664121AC@x-press.net>
sorry I can't type tonight
the image is actully here
http://www.angelfire.com/on2/lycosrp/images/silence640x480.jpg
Subject: Re: for once a question on why something does what it does insted of how to do something
Date: 11 Jul 1999 22:31:24
Message: <37895321.74B23E5F@pacbell.net>
> thanks!!
Mike's tutorial can explain it better than I can:
http://members.xoom.com/POVRAY3/media2.html
Ken Tyler
mailto://tylereng@pacbell.net
Date: 13 Jul 1999 01:24:34
Message: <378ACD76.725DF5DE@aol.com>
Basically you have a 'scattering'-only media there, for one thing, and
'intervals' is going to matter most. Use a large intervals number to get
smoother "atmospheric" media, smaller number for speckles. It helps
greatly (even required almost) to have a "world container" object
instead of nothing at all or 'sky_sphere' or 'background' alone when
trying for smooth media. The container helps to confine the media
better. Use 'density' in it too and you'll see a change.
As you may find, 'media' is not a well known subject, by all anyway.
Mostly well known for it's peculiarities as you have seen. Keep reading
and asking about it.
> code
> media {
>   intervals 20
>   samples 1, 10
>   confidence 0.9999
>   variance 1/1000
>   ratio 0.9
> light_source {
> cylinder
> radius 10
> falloff 10
> thanks!!
> work!!
 mailto://inversez@aol.com?Subject=PoV-News
