POV-Ray : Newsgroups : povray.newusers : CSG Newbie-esque question. Server Time
21 Sep 2025 02:24:53 EDT (-0400)
  CSG Newbie-esque question. (Message 1 to 3 of 3)
Subject: CSG Newbie-esque question.
Date: 26 Feb 1999 19:30:18
Message: <36d73c9a.0@news.povray.org>
I am currently working with POVLAB.  I have a basic understanding of CSG's
in POVRAY, and have started working with POVLABs supported CSG option, but
am having some trouble.  Basically, I'm trying to make a hole between 2
objects, but I can't get it to work.  Is this simply a POVRAY
impossibility, or a POVLAB limitation?  I have 2 tubes, both of which are
vertical.  When I put something between them, like say a cube, and then
perform a CSG Difference operation on ONE tube and the cube, the cube
makes a succesful hole in that tube as expected.  However, I have no clue
how to make a hole clean through both tubes.  I performed different
Difference operations, but the only thing I usually wind up with is 2
invisible tubes with the cube as visible.  I've tried playing with the
function, but I cannot seem to get this to work.  I respectfully ask for
some serious help....I can't seem to figure it out.  Thanks in advance...
psl### [at] nmiacom
Subject: Re: CSG Newbie-esque question.
Date: 26 Feb 1999 20:39:24
Message: <36d74ccc.0@news.povray.org>
Making a CSG difference leaves only the first component visible. You must
either difference both cylinders separately with the same cube - or better
yet, make a union of these cylinders and difference this union with the
cube.
Margus
psl### [at] nmiacom wrote in message <36d73c9a.0@news.povray.org>...
>psl### [at] nmiacom
Date: 26 Feb 1999 20:52:22
Message: <36D74FA8.6C8CE6C0@aol.com>
First difference the two tubes then difference the result from the cube,
like so:
difference {
 object {Cube}
difference {
  object {OuterTube}
  object {InnerTube}
Hope I've followed correctly.
> psl### [at] nmiacom
 mailto:inv### [at] aolcom?PoV
