POV-Ray : Newsgroups : povray.newusers : Help me. Please Help me. I feel totally crazy Server Time
11 Oct 2024 02:21:35 EDT (-0400)
  Help me. Please Help me. I feel totally crazy (Message 1 to 4 of 4)
Subject: Help me. Please Help me. I feel totally crazy
Date: 25 Feb 1999 09:08:54
Message: <36d55976.0@news.povray.org>
I join a pov file with an object, i'm working on. I got a black circle (hole
?) on my csg object. I'm searching for hours what's wrong, but i don't find
anything.
Please, can somebody here help me ??
What's wrong in my object ?
Download 'test.pov.txt' (2 KB)
Subject: Re: Help me. Please Help me. I feel totally crazy
Date: 26 Feb 1999 20:34:06
Message: <36D74B62.3CF925F4@aol.com>
'inverse' used either within the Machin object (used in Machin1) or the
'difference' of it and the smaller sphere removes the spot (it is the
inner sphere or hollow caused by it you see). I have no explanation for
this effect. Appears to cause a hole in the surface.
I tried a difference on the 2 test objects for a cut-away view and only
the correct one on the left side seems right no matter what I tried. The
one on the right (incorrect) did not have the proper interior.
Anyhow unless you are going to be viewing the interior the 'inverse'
will fix it.
Something odd does seem to be going on though, just wish I knew what.
> anything.
> //  totally crazy ????
> #version 3.1;
> global_settings
>   assumed_gamma 1.0
> // a camera
> camera
>   location  <-12, 0, 0>
>   look_at   <7, 0, 0>
> // some lights
> light_source { <-5,3,-5> color rgb <1,1,1>}
> light_source { <-5,3,5> color rgb <1,1,1>}
> light_source { <-5,-3,-5> color rgb <1,1,1>}
> light_source { <-5,-3,5> color rgb <1,1,1>}
> // A Tube
> #declare Tube=difference {
>         cylinder {-2.6*x,2.6*x,.2}
>         cylinder {-2.7*x,2.7*x,.15}
> // I put it around a sphere
> #declare Machin=union {
>         sphere {0,2.5}
>         #local Nb=1;
>         #while (Nb<9)
>                 #local Angle=(360/8)*Nb;
>                 object { Tube
>                         rotate 25*z
>                         rotate Angle*y
>                 object { Tube
>                         rotate 50*z
>                         rotate (360/16+Angle)*y
>                 #local Nb=Nb+1;
>         #end
> // I want to make this object empty
> // So I make a CSG difference with a sphere
> #declare Machin1=difference {
>         object {Machin} // Radius of sphere : 2.5
>         sphere {0,1} // a smaller radius
> object {Machin // Not empty object
>         translate 3*z
>         pigment {color rgb 1.5*<.6, .25, .15>}
>         finish {ambient 0.4}
> object {Machin1 // empty object : what about the black circle on his surface !!!!!
>         translate -3*z
 mailto:inv### [at] aolcom?PoV
Date: 1 Mar 1999 05:43:42
Message: <36da6f5e.0@news.povray.org>
Sorry, but my english is too poor to understand your explanation. Can you
post my code modified please ?
Thanks
Laurent bassompierre
lba### [at] ubifr
>will fix it.
Date: 4 Mar 1999 23:11:47
Message: <36DF594D.53F236B2@aol.com>
So sorry I didn't get back to you earlier, I don't read this group as
often as others. Following is your scene file re-done. Not sure if it
will make any more sence, I am still puzzled by the behaviour
surrounding it, though it is fixed(?).
#version 3.1;
global_settings
  assumed_gamma 1.0
// a camera
camera
  look_at   <7, 0, 0>
// some lights
//light_source { <-5,3,-5> color rgb <1,1,1>}
//light_source { <-5,3,5> color rgb <1,1,1>}
//light_source { <-5,-3,-5> color rgb <1,1,1>}
// A Tube
     // pigment {rgbf 1}
        sphere {0,2.5}
        #local Nb=1;
        #while (Nb<9)
                object { Tube
                        rotate 25*z
                        rotate Angle*y
                object { Tube
                        rotate 50*z
                #local Nb=Nb+1;
        sphere {0,1 pigment {rgb<0,1,0>} finish {ambient 1}} // a
smaller radius
      inverse
//difference {
 union {
        translate 3*z
     //inverse
surface !!!!!
        translate -3*z
     //inverse
// plane {x,0 pigment {rgbf 1}} //attempted cut-away looks strange (-x
if inversed above)
   //inverse
> Thanks
> lba### [at] ubifr
> >will fix it.
