POV-Ray : Newsgroups : povray.newusers : Stripes on a poker chip Server Time
25 Dec 2025 10:05:38 EST (-0500)
  Stripes on a poker chip (Message 1 to 3 of 3)
Subject: Stripes on a poker chip
Date: 23 Feb 1999 18:22:53
Message: <36D3376F.52DDCF31@yahoo.com>
Greetings, all.
I've got a set of poker chips that I want to model and use in a scene.
They're essentially smooth, but have a small "ring" subtracted from each
face.  That's not the hard part - the hard part is figuring out how to
apply the cool contrasting-colored stripes.
Essentially, each chip has two stripes every 120 degrees around the
edge.  The two stripes extend from the edge to the small inner groove
(about 25% the radius), and are visible on the edge of the chip as well
as the face.  The two stripes are parallel to each other - they do *not*
angle toward the center of the face.  The space between the stripes is
as wide as one of the stripes themselves.
How can I best render this color pattern?  It seems too simple and
(relatively) easily defined to have to bother with a full-fledged
imagemap.  I've been toying with some weird combination of CSG objects
in opposing colors, but can't quite think it through.
I feel like the fact that I can't figure this out points out some gap in
my POV-Ray knowledge - can anyone help?
Thanks in advance,
-Scott
Subject: Re: Stripes on a poker chip
Date: 25 Feb 1999 07:27:06
Message: <36D54110.8DD6B794@pacbell.net>
Scott wrote:
> Greetings, all.
> Thanks in advance,
> -Scott
 I'm posting a small file in povray.text.scene-files called chips.pov
that should answer your question for you. Drop by povray.binaries.images
for a preview to see it that is what you had in mind.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 27 Feb 1999 20:45:44
Message: <36D8CA74.982A923A@ij.net>
	There are probably a dozen ways to do anything but if the
angling is your problem, put it on a box of chip thinkness then
difference with a cylinder of the right diameter with such
stripes on its curved surface. Without any rotation they should
match up. A couple more difference cylinders of the inner rim
size and you have the CSG shape.
