I'm used to using macros in programming, but I can't seem to get the
hang of POV macros. There seems to be some inconsistencies in how they
work.
For example: If I choose to 'stub out' a macro and force a value
thusly..
#macro TestMacro()
(1)
... it works fine. But, if I try to select from several values using a
switch statement thusly...
#macro TestMacro( xValue )
#switch (xValue)
#range (0,9)
(0)
#break
#range (10, 19)
(0.5)
#break
#else
(1.0)
... I get errors.
What I'm trying to do is calculate a color value [I'm using different
macros for fRed(), fGreen() and fBlue()] based upon a rotation value
(passed as xValue). I'm using the macros in a statement like this:
"color [rgb<fRed(xAngle), fGreen(xAngle), fBlue(xAngle)>]"
Any suggestions anyone can make would be greatly appreciated.
Patrick Hagerty
pat### [at] hagwarecom
On Thu, 21 Jan 1999 13:13:01 -0500, Patrick Hagerty <pat### [at] hagwarecom> wrote:
Are those square brackets really there in what you're using? The
only place I've ever seen square brackets is in the various maps
(color_map, pigment_map, etc.)
No, as a matter of fact I totally screwed up the syntax. I am actually using it in
a color_map, but I tried to short-cut the syntax for the purposes of illustration.
The actual code is:
color_map
[0 rgbt <fRed(xAngle), fGreen(xAngle), fBlue(xAngle), 0>]
[1 rgbt <fRed(xAngle), fGreen(xAngle), fBlue(xAngle), 1>]
Sorry for the confusion.
Patrick
I tried the implementation of TestMacro that you posted, and I
can use it without problems in the following code:
#declare xangle=11;
#declare yangle=5;
#declare zangle=20;
sphere {0,1
gradient y
color_map {
[0 rgb <TestMacro(xangle),TestMacro(yangle),TestMacro(zangle)>]
[1 rgb 1]
Perhaps you could post the exact code of one of your macros, or
tell us what error you're getting.
I had the same problem in my Particles Generator file. So I used a variable to
return the value.
#macro MyMacro(value, return)
#switch (value)
#case (0)
#declare return = value * 20;
#break
#case (1)
#declare return = value *10;
#break
Hope it helps !
David GEMELLI
Well, I'm red-faced. I can't for the life of me figure out what happened. As a
result of your message I revisited my source and what I thought didn't work is now
working. Maybe I had a typo that I hadn't noticed before or something, but
everything is working as I wanted it too.
Thanks for your comments. I really appreciate your taking the time to help me while
I worked through this.
Patrick
> #declare xangle=11;
> #declare yangle=5;
> #declare zangle=20;
> sphere {0,1
> texture {
> pigment {
> gradient y
> color_map {
> [1 rgb 1]
