POV-Ray : Newsgroups : povray.newusers : order of operations Server Time
19 Jun 2026 23:50:42 EDT (-0400)
  order of operations (Message 1 to 4 of 4)
Subject: order of operations
Date: 6 Nov 1998 00:06:09
Message: <364283F1.6B75FF61@pilot.msu.edu>
In my endeavors to render scenes I find myself needing to scale
translate and rotate objects. Only different things happen if I do them
in different orders. ie. I had a cylinder I scaled down by .25 in ann
three axes and I had to translate it -50*z to get it where I wanted it.
How do theses operations affect each other? Should I always translate
first, scale and then rotate?
Drew
Subject: Re: order of operations
Date: 6 Nov 1998 00:17:12
Message: <36428617.E4063F8E@pacbell.net>
> Drew
    In one of the pov versions this was covered quite well
in the docs. Perhaps it's gone now.
   Anyway your safest route is scale, rotate, then translate.
Unexpected things will  happen if you stray from this order.
Ken Tyler
Date: 6 Nov 1998 03:53:43
Message: <3642B912.DF169C6E@peak.edu.ee>
> Ken Tyler
Another useful trick is to scale, translate and then rotate - the object orbits
at a distance from the origin specified by translate. Scaling should almost
always be first, though.
Margus
Subject: Thanks guys. (n/t)
Date: 6 Nov 1998 12:24:35
Message: <3643312C.38206749@pilot.msu.edu>
